"Get it in gear!"
Discussion in 'Questions From New Drivers' started by J Man, Jan 18, 2012.
  1. J Man
    J Man Medium Load Member
    306
    197
    Dec 31, 2011
    Middle of nowhere
    Cruising along unloaded down a two-lane highway, speed 45mph (that's 7 HI in this 18 speed at 1300 RPM) and the instructor tells me he wants me to make a left ahead - that's an easy 3rd gear turn and I start dropping gears. 7 HI to LO, then down to 6th, then I'm slowing to go to 5th when a car starts pulling into where I need to turn. So I'm going to need to stop on the highway so I concentrate on just slowing down now (can't operate the accelerator and brake at the same time) but I'm in Neutral. I figure I'll get slowed down, then come in on 4th, then 3rd, then if the car is out of my way I can make my turn. Of course, this is a no-no because now I'm coasting more than a truck length out of gear. "Get it in gear! Get it in gear!" So I'm grinding trying to catch 4th, but I'm moving too fast for it to just go in, but I have to take my foot off the brake to RPM up, and then I'm not slowing fast enough anymore. Fun times. I do catch 4th, then 3rd, then 2nd, car clears and I make my turn, but I get an ear-full for grinding gears and, of course, being out of gear. Gah, bad day. :biggrin_25510:
  3. J Man
    306
    197
    Dec 31, 2011
    Middle of nowhere
    Oh, we don't get to float gears or skip gears when the instructors are paying attention, so you have to double-clutch every gear down.
  4. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    That's the way it goes! it will get better
    J Man Thanks this.
  5. J Man
    306
    197
    Dec 31, 2011
    Middle of nowhere
    I hope I get better sooner rather than later. ;)
  6. fordfan17
    fordfan17 Bobtail Member
    31
    12
    Jun 1, 2009
    Homer City, Pa
    :yes2557:
    We all had started at one time. I've been doing this for 36 years and i've yet to see anyone just starting get it right from the very get go. Hang in there and before you know it you'll have it right. Good luck and Hang in there.
    Germangirl, J Man and Wargames Thank this.
  7. gravelhauler
    gravelhauler Medium Load Member
    630
    412
    Oct 20, 2011
    Lake Charles, La
    You're learning on an 18 spd. I tip my hat to you. Alot of em screw up with only half as many gears to deal with.
  8. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    You can get use to tilting your foot sideways to hit the throttle and brakes at the same time. Don't be afraid to drop two gears at once, especially if you get to where your lugged way down around 900rpms just skip right across from 7th to 5th don't bother with the splitter once you've lost that many rpm.
    J Man Thanks this.
  9. andy
    andy Light Load Member
    213
    72
    Oct 16, 2010
    MT
    I don't know anyone who double clutch down shifts every gear. Learning with an instructor and being on your own are VERY different. You will see.
    J Man Thanks this.
  10. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    Yep My first time with a trainer. right off I stall the truck! He laughs and say's now I know you went to school with an empty truck, but now you have to give it a little fuel! It's full
    Lady K Thanks this.
  11. Logan76
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    weird, I dont understand Ron. I was taught not to use fuel when your starting off in a truck?
