Getting a truck home with a bad differential
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DMAX66, Oct 18, 2018.
  1. DMAX66
    DMAX66 Light Load Member
    170
    146
    Nov 11, 2010
    Chicagoland
    I have a truck out on the road with a bad rear differential. I was wondering if I can pull the rear drive shaft and rear axles and just run it on the front differential to get the truck home. Obviously use something to cover the hubs so I don’t loose fluid.
    Rideandrepair and Oxbow Thank this.
  3. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Yes, you can do that.
  4. DMAX66
    170
    146
    Nov 11, 2010
    Chicagoland
    Awesome, thanks
    Rideandrepair, Oxbow and Cattleman84 Thank this.
  5. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Are you sure the rear diff is bad? And not the front diff?
    Being the front diff is the main diff, and is used the most.
  6. DMAX66
    170
    146
    Nov 11, 2010
    Chicagoland
    No it’s definitely
    no it’s definitely the rear. A bearing failed and slightly cracked the case
    Oxbow and x1Heavy Thank this.
  7. wore out
    wore out Numbered Classic
    16,633
    202,885
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    That is a myth that one diff is used more than the other. They pull equal.
    I have pulled axles and locked the power divider in and ran 750 miles home before wasn't a real big deal
    snowman_w900, SAR, bzinger and 7 others Thank this.
  8. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    The rear diff is the driven diff when the power divider isn't locked in.
  9. AModelCat
    161,297
    That statement will go over the heads of 95% of the people who read it unfortunately.
  10. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Wrong.
    It can be any one of the 4 wheels on a tandem application. People always thing it's the rear diff that drives.
    It's what ever tire has the least amount of traction that is going to spin. Could be left,right,front or back. You actually have 3 differentials in a tandem setup with a power divider.
    Troy_, snowman_w900, SAR and 5 others Thank this.
  11. Lyle H
    Lyle H Road Train Member
    1,291
    2,938
    Apr 16, 2014
    If you really want to get them scratching their heads, tell them that when one wheels spins, all the power goes to the spinning wheel.
    And when it’s spinning, it’s actually spinning 4 times faster than normal.
    AModelCat, KVB, Oxbow and 1 other person Thank this.
