Getting all new drives, need advice on lowering RPM
Discussion in 'Ask An Owner Operator' started by georemo, May 13, 2021.
  1. georemo
    georemo Light Load Member
    74
    65
    Mar 28, 2020
    I'm getting 8 new drive tires and was thinking about switching to tall rubber to lower the RPMs.
    Truck came originally with 295/75r22.5G BR tires
    3.36 rear ends
    13 speed RTLO-18913A
    Volvo VNL780 D13 455hp EcoTorque
    most loads are 40k or lower, rarely 42-44k.
    Terrain is mixed, I-81 NY-Carolinas I-80 across PA, Ohio turnpike, Indiana Tollway, I-70 Ohio-Indiana I-90 NY
    I cruise at 65-75 depending on where I am, 75mph at 1600 rpms is killing my MPG and for a terrain like Ohio turnpike it'd be ideal to cruise at say 1300 or 1400
    and last, would there be any height clearance issues with tall rubber pulling a 53ft box? I currently make it under a 13ft4 close to where I park but not sure how accurate that is sign is.
    Thanks a bunch
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,519
    9,827
    Mar 30, 2014
    I believe the diameter difference is 2 inches, which would make it ride 1 inch higher
    baha and georemo Thank this.
  4. WHY NOT
    WHY NOT Light Load Member
    160
    117
    Oct 18, 2015
    tall tires may help lower your rpm but at 75 you're still pushing a bunch of wind. The gain on MPG will probably be very little. The best way to help is to slow down, keep the engine in the right rpm range climbing hills don't bog it down etc. I went from 22 lows to 24 low's with my 3.25's and dropped about 100rpm's. (24 lows are the same height as 22 talls)
    Bean Jr., slow.rider and georemo Thank this.
  5. DUNE-T
    DUNE-T Road Train Member
    7,001
    17,016
    May 10, 2015
    Detroit, MI
    I have done the same experiment, mpg got worse, because I constantly had to downshift, since engine was not operating at the proper rpm
    baha, Brettj3876 and georemo Thank this.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,059
    Nov 18, 2014
    Land of local
    Yep. My uncle tried tall 24.5 and next tire change went back to the Lo pros
    Swine hauler, baha and georemo Thank this.
  7. georemo
    74
    65
    Mar 28, 2020
    Thanks for the helpful inputs, I may end up giving it a shot and cruise slower at 68 mph, 1 inch height increase would be a bit of an issue though, as well is having to downshift often, but not sure if that would be an issue with 3.36 rear ends and the 13 speed
  8. slow.rider
    slow.rider Road Train Member
    2,005
    4,740
    Apr 4, 2017
    NYC
    Tires with low rolling resistance can help some. What make and model tires do you have? Also trailer skirts and fins do help if they're an option. Another tactic could be to use 4 drives and 4 trailer tires.
    Bean Jr., baha and Midwest Trucker Thank this.
  9. Rideandrepair
    17,387
    56,448
    Aug 8, 2015
    Aren’t Lo pro tires supposed to have less rolling resistance than tall tires?
  10. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,419
    6,712
    Oct 22, 2016
    North Dakota, Eh?
    Supposed to.
    Brettj3876 Thanks this.
  11. Brettj3876
    11,257
    54,059
    Nov 18, 2014
    Land of local
    Not sure but I would think so? Less flex and all
