Getting Class B by myself (Tampa, FL)
Discussion in 'Questions From New Drivers' started by Hmshood, Mar 21, 2018.
  1. Hmshood
    Hmshood Bobtail Member
    19
    4
    Jan 12, 2018
    I know I'll have to rent a truck with air brakes, is the test pretty easy compared to a Class A? I took the class A and aced the pretrip and backing, but for the road test but I hit a curb which is an automatic failure. I can't seem to figure out what is involved for a class B test
    Thanks for any advice
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,757
    Sep 20, 2014
    Why don't you try to retake the test?
    jammer910Z Thanks this.
  4. Hmshood
    19
    4
    Jan 12, 2018
    I don't have the money to rent a semi, and I only want a class B anyway
  5. ChaoSS
    3,338
    6,757
    Sep 20, 2014
    Well then, the test is the same. The skills test is the same, except you have less room to move around since your aren't dragging a trailer. Obviously be pretrip on the trailer. But you will need need a vehicle to take that test.
    If you plan on getting a p endorsement there is more to the tests.
    Dan.S Thanks this.
  6. Pobos33
    Pobos33 Bobtail Member
    Mar 21, 2018
  7. Pobos33
    Mar 21, 2018
    Don' waste your time on a class b it' not worth it...just retake the class a just remember to make wider turns & slow down... good luck
  8. Ridgeline
    22,374
    116,079
    Many ALL rental companies require you to have a CDL to rent a truck that is over 26,000 lbs gvw which is needed to take a class B test.
    Mike2633 and Dan.S Thank this.
  9. Dumdriver
    Dumdriver Road Train Member
    1,525
    2,138
    Jul 8, 2014
    East Coast
    I know it takes more than that with the major companies (Ryder, Penske etc etc) now. They all require you have a corporate account set up with them.
    Mike2633 Thanks this.
  10. ChaoSS
    3,338
    6,757
    Sep 20, 2014
    There are companies that will rent out trucks just for a test, generally with a guy who will sit in the passenger seat when legally required.
