Getting fired during 2 week notice?
Discussion in 'Questions From New Drivers' started by Travelworld2067, Jun 9, 2018.
  1. Travelworld2067
    Travelworld2067 Light Load Member
    297
    107
    May 10, 2018
    So was in a small fender bend and a speeding violation. The comoany im going to already ran dac and psp. Good hired. Have a flight next week i have a feeling from talking with safety over phone that they are gonna fire me when i get back to yard day after tommorow. My job here ends on thursday. Not sure what to do will the company im going to now find out and care?? Or should i juat let things run their course and go to orientation??
  3. Chinatown
    Chinatown Road Train Member
    75,004
    171,007
    Aug 28, 2011
    Henderson, NV & Orient
    Send an Email and resign, before they get the chance to fire you.
    This way you have proof with date and time you resigned.
    You don't need to give a reason to quit a job, but if you really want to, just say you "resign to pursue other opportunities. Where do you want the truck returned?"
    Edit: A company can't fire you if you don't work there. Resign before they have the chance to fire you.
  4. DTP
    DTP Road Train Member
    1,281
    2,708
    Dec 9, 2014
    Can you afford to be out of work for say a month or so? If you can, tell them and roll the dice. If you need the $, just go to work at the new job and chance them not finding out, at least for a while until you can build up your savings. Good luck
  5. Travelworld2067
    297
    107
    May 10, 2018
    If i quit now will they still be able to dac me for accident?? It happend like may 15. I havent really heard anything. They called me to tell me i shouldnt have been on pc staus through nyc since i was going to pick up load. Its just the way he said it.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    You apparently have a flight to the next orientation set up.
    Put the truck in the yard and turn in your notice prepared to get on that flight fired the moment you turn in that two week notice.
    Document everything. Name names written down long hand in a journal to assist in explaining everything to new employer.
    be prepared to challenge your dac. Get a driver video cam for facing forward that you own and hold the video on anything that happens. So cheap these days for a good one and a few moments of he said she said is settled either way with that video.
    Savings always. Trucking is not something to settle into thinking no one will fire you or you are too important to be fired etc. Forget all that. One day at a time.
    DO communicate above the problem source person like a bad dispatcher to operations manager or owner. His bosses. Now safety has a seperate position and in the case of being dispatch to get a load empty it's not PC. You are at work. So safety did good there. They have to. Otherwise Uncle Sam will have leaned on the entire company for violations.
    Follow me so far?
    be prepared for anything and everything each day. If you are already talking quitting, there are three sides to every story and usually more comes out on TTR on page three or something. Usually if you hit stuff that does not move or is not moving it's preventable. If it involves hurt or death or towing or fire, police etc on up it's more bad for you. Depending.
    A sufficient number of issues in any company sinks a driver quick. That is why a percentage of new hires are out of the industry for a while until the DAC cools off in three to 7 years depending on the nature of the violations done.
    angrytrans and Travelworld2067 Thank this.
  7. Chinatown
    75,004
    171,007
    Aug 28, 2011
    Yes, they can DAC you, but life goes on. DAC probably won't show up for awhile though. Life goes on. Some companies don't even use DAC.
    Travelworld2067 Thanks this.
  8. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    Travelworld2067 u have some good stories.
    driverdriver and Travelworld2067 Thank this.
  9. brian991219
    brian991219 Road Train Member
    2,955
    5,954
    Aug 10, 2013
    Lords Valley, PA
    Yes, this will show up. Yes, you need to disclose it to the new company. Most likely you will have to fill out a form listing any accidents, tickets, etc at orientation. This will be checked against a new copy of you driver license abstract and possibly a new DAC report.
    If you fail to disclose the recent accident the new company will fire you without question. Tell them upfront and they may let it slide since you were honest. If they fire you and they use DAC, which I assume they do since you said they have already run your report, they will report that you gave false information on your application as reason for terminating you which will make it very hard to get hired anywhere else for a while.
    You had an accident, it happens as none of us are perfect, but trying to hide it from future employers will not get you anywhere.
  10. x1Heavy
    34,017
    42,137
    Mar 5, 2016
    agreed. Nothing personal. Share with them what happened with the whoopsie.
    THEY WILL FIRE YOU if you happened to be 2000 miles from home at that instant the moment they learn that you did not disclose a whoopsie. Someone is probably coming to get your whole rig or you will be told to come through a yard and then fired right there. My last firing was literally by a single satellite message after they matched the truck to the Arkansas Protho Yard way back when.
    I had to laugh, I knew that was coming when dispatch support stopped being normal with usual daily business stuff a few days prior.
    bottomdumpin and Travelworld2067 Thank this.
  11. Travelworld2067
    297
    107
    May 10, 2018
    See i told about speeding but the accideny being so minor it may not show in dac ive had another incident where i hit a truck backing no dac report issued. Little things too busting my bumper nothing shows.. they do use dac here tho.. and honestly i feel i wasent at fault but neither did the other guy so im not sure how insurance will rule whos at fault and if itll even show since in the past none of my little incid3nts showed up
    x1Heavy Thanks this.
