Getting more out of an inverter
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by PaladinJack, Nov 19, 2017.
  1. PaladinJack
    PaladinJack Bobtail Member
    11
    Jun 9, 2017
    Upstate NY
    Okay. So.
    An inverter plugged into a 12v outlet with a 10-amp fuse on it is going to top out at (P=V*I) 120 watts output (theoretical, real-world will be about 100-110W thanks to inefficiencies in the inverter). Unfortunately, the computer I have draws about 150 watts -- the 400/800 inverter I have won't run it.
    Anyone have any suggestions on how to get more wattage out of the inverter, to bring it closer to its specced output? I work for a company that doesn't allow heavy-duty inverters installed in their trucks, and let's say for the sake of argument that I don't want to violate policy.
  3. Brandt
    Brandt Road Train Member
    4,503
    6,161
    Sep 17, 2012
    That's about all you can get out of the 12V plugin inverters. Make sure your idling the truck. That might give you a little more power.
    Maybe a set of mini jumper cables seems like I remember seeing inverter with some. So you could clip them onto batteries when ever you used it. You cannot do 2,000 watt but maybe 400-500
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Not from a 12 volt outlet.
    We used a 300 watt inverter to run a dell inspiron laptop most of 2000 and 2001. Most of it was made of metal (The inverter) and cooling on the plastic dash became problematic. We stick a armorer's block (A small slab of metal with holes meant to assist in detail stripping a colt) under there with velco and then fastened the inverter to the top. That 300 watter ran off a 12 volt.
    The real monster inverter was hard wired to batteries of the truck direct by the freightliner dealer at our expense. That one was able to start anything up to close to 5000 watts, however that engine needed to be running at cruise idle and pushing 15 volts on the alternator to the truck to succeed. In addition the lower bunk had to be up with a fan directed at the inverter for cooling purposes. 4 deep cycle batteries fed it.
