Getting Towed 2014 Volvo 670 I shift with 53’ dryvan attached need info
Discussion in 'Ask An Owner Operator' started by Siinman, Dec 16, 2021.
  1. Siinman
    Siinman Road Train Member
    Mar 5, 2017
    5,269
    Thanks Received:
    13,335
    Kansas City, MO.
    Got towed last night in Miami. Only went about 12 miles but the guy did not drop axle or disconnect drive shaft. Was reading that doing that would mess up transmission? Is this correct? I have only been towed one other time and I was not with the truck so don’t know how guy did it.
    first tow had to go to their yard for the night. Now I am going to the dealer but he is having all sorts of problems trying to get it ready. I think this is his first big truck tow.
    any knowledge would be great. I want to talk to the dealer when I get there so they know.
  2. Siinman
    Mar 5, 2017
    5,269
    Thanks Received:
    13,335
    Kansas City, MO.
    Forgot to mention it was towed with my dryvan attached. Last time I got towed it was bobtail and they picked it up from the rear.
  3. Brandt
    Brandt Road Train Member
    Sep 17, 2012
    4,500
    Thanks Received:
    6,157
    Just had my truck towed bobtail. They hooked up from back. So they lift the drive axles off the ground. They did that to so they would not have to remove the drive shaft.
    Speed_Drums and Siinman Thank this.
  4. Siinman
    Mar 5, 2017
    5,269
    Thanks Received:
    13,335
    Kansas City, MO.
    Just got off phone with dealer. They said it very well could mess up something. They will document it with me when I get there. Now the guy is trying to drop the drive shaft. Been messing with this for 2-3 hours and still not at the shop. FML.
  5. AModelCat
    29,159
    Thanks Received:
    158,632
    I don't know the specifics of the IShift but you can definitely do damage to Eatons towing them at speed for a distance.
    flood Thanks this.
  6. Brandt
    Sep 17, 2012
    4,500
    Thanks Received:
    6,157
    If still hooked to trailer plus ishift, they probably messed something up. I'm not mechanic but they always pull drive shaft out if towing with drive axles on ground.
    MOBee and feldsforever Thank this.
  7. Siinman
    Mar 5, 2017
    5,269
    Thanks Received:
    13,335
    Kansas City, MO.
    Well the truck is at the shop and most likely won’t know till Monday or Tuesday. They pulled the truck and trailer about 5 miles and was doing 10-20 miles an hour. I sure hope it didn’t f things up but will find out. Ok
    feldsforever Thanks this.
  8. JonJon78
    JonJon78 Road Train Member
    Jul 1, 2018
    7,151
    Thanks Received:
    38,877
    What was the problem with your truck that required a tow?
  9. Siinman
    Mar 5, 2017
    5,269
    Thanks Received:
    13,335
    Kansas City, MO.
    Stupid hose broke wear the DPF is and ran all the Anitifreeze out. This is the second time that happened. Should had replaced all the hoses at that time.
    JonJon78 Thanks this.
  10. Bean Jr.
    Bean Jr. Road Train Member
    Mar 30, 2014
    5,500
    Thanks Received:
    9,782
    The pump on truck transmissions works off the input shaft. Towing them without dropping the driveshaft or pulling an axle means the output shaft is turning without lubrication. I got put OOS at the sb I65 scale near Crown Point. Because it was cold, we towed it to the shop next to the Flying J at exit 240. Instead of dropping the shaft, the driver had me run the engine for the 5 mile tow.
    Oxbow, TallJoe, Speed_Drums and 4 others Thank this.
