Glider Kit CAT OR Detroit
Discussion in 'Trucks [ Eighteen Wheelers ]' started by steigercat, Oct 19, 2013.
Thread Status:
Not open for further replies.
  1. steigercat
    steigercat Bobtail Member
    Oct 19, 2013
    I am going to buy a glider kit for short haul 80000 gross trucking. I have a Peterbilt 389 specced out but am having trouble deciding on an engine. I am either going with a 550 Cat or 500 Detroit Series 60 12.7. Both engines are early 2000 pre emission with a factory rebuild and will be mated with an 18 speed. The Cat will have a 4 year unlimited mileage full warranty and the Detroit would be a 3 year unlimited mileage limited warranty. The Cat will be 350 pounds heavier and cost $4000 more than the Detroit which are the negatives. The better warranty and more power are the positives. Fuel mileage is important and I am wandering how much advantage the Detroit will have with that. I would like to hear opinions or what you would go with and the reason.
    Thanks
    Road Killer Thanks this.
  3. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    that 12.7 detroit is really a great engine,and at 500 hp will have enough power, plus the fuel mpg should be a little better. i always was a cat man that was the only motor i would buy,but the detroit is really a great motor, i ran them for years after i got out of the o/o business. lots of luck on your choice PS the detroit shops are rebuilding those motors with a bigger turbo and speced at 600 HP. seen one at the detroit shop in des moines iowa not too long ago
  4. popcorn169
    popcorn169 Road Train Member
    2,194
    1,714
    Sep 5, 2011
    state of confusion
    Detroit is cheaper to work on than a CAT and Detroit has better fuel mileage. CAT is a tough engine so it is kind of a preference thing.
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    DETROIT DETROIT DETROIT!!!!!!!!
    S60 is one heck of a motor. They run forever, get great MPG, and if you downshift they pull great. S60 does like higher RPM then cat though, so if you want to pull the hills just like a Cat, drop one gear and you'll keep pace with um. I have an S60 and I can out pull most guys on hill fully loaded. Mines not even tuned up or modded. The rummer that cats pull better then detroit is BS....drives just lug detroits to much and they don't like that. Keep rpm 200 higher then cat and it will pull fine. My detroit has 720,000 miles on it..never had inframe or any major work and it eats a gallon of oil every 20,000 miles. Oil samples look great to. Not bad for an old engine.
    If you really want power, the s60 can be tuned to over 550 by just changing the computer code and over 600 with a few mods.
  6. rollin coal
    rollin coal Road Train Member
    13,304
    26,909
    Mar 29, 2008
    TN
    Heavy loads - I'd take the CAT. It'll get good fuel mileage maintaining and driving it right. Doubt you'll even need the warranty with a 6NZ. Parts are only expensive when they break. In 4 years the only part that broke in mine was a $6 spring in the pac brake. I did do some other necessary upgrades when I bought it due to the fact it was a bridge motor and it was inframed at 1.1 million but the only thing that's ever broke (aside from a million plus miles cracked liner) in the 400,000 miles I've had it was that pac brake spring.
    Road Killer and Hammer166 Thank this.
  7. popcorn169
    2,194
    1,714
    Sep 5, 2011
    state of confusion
    Since both are factory rebuilds then you should not have to many issues if they where done right.
    rollin coal has a good point. Do not drive it like you stole it and if you drive it right mileage will be there. The older CAT engines where a great engine as where the Detroits.
    Rollin Coal a six dollar part is not bad at all for the miles on it. Bet you can't do that with a new engine.
  8. craggy1982
    craggy1982 Light Load Member
    205
    386
    Apr 21, 2012
    KY
    I love my cat even though its an acert. I do generally get outpulled by a Detroit even when I try to keep it from happening. but I generally baby my motor and I don't push it. I run 80k constantly and most times im slowest guy going down the road and creeping up the hills. I never get in a hurry and don't care if im the last one getting somewhere. because I drive like that I haven't had a lot of the problems with my acert that other people have had. a buddy of mine drives his like he stole it and constantly breaking studs in his exhaust manifold and he cant understand why I never do. maybe im lucky, or maybe its because I dont run my truck as hard as he does.
  9. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I have an exhaust manifold leek on mine...Maybe Im driving it to hard lol. (i think that was preexisting to me owning it) I only get out pulled by the tripped out chrome petes that got like 800 horses under the hood. You can tell the guys is a SUUUUUPPPPPPERRRR trucker prob getting 3 or 4 mpg. I norm run 65 for cruise and the motor seems to be ok with it.
    craggy1982 Thanks this.
  10. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    iv been very happy with my 60s detroit as a owner id take one over a cat any day. now if i was a driver and not paying the bills id prefer the cat. but once you get used to driving the 60s there really not bad to drive and get great mpg
  11. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    For that light weight, the DD S60 is all you need. You wont need the extra power and CI's till you haul over 110,000lbs every day.
  • Thread Status:
