Glider rules question
Discussion in 'Trucking Industry Regulations' started by Phantom307, Mar 2, 2024.
  1. Phantom307
    Phantom307 Light Load Member
    222
    210
    Jul 5, 2019
    Cheyenne
    I am looking at a Cascadia 2012 with a 12.7 Detroit. It isn't titled as a glider, was just done in a shop of some small trucking company. I want to know if I am going to run into problems possible with this sort of arrangement. Know better than to take it into California, and I heard theres some rule from 1991 about emissions engines and truck years but thats as far as i know. clarification would be greatly appreciated. Thanks
    Vampire and Northeasterner Thank this.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Technically if it was not designated as a glider by the manufacturer as indicated in the serial number, then it is a regular 2012 and requires egr,dpf and def emissions.
    Getting the engine swapped to a 60 Series basically means it’s been deleted and is not a legal road worthy truck.
    If you were going to run it local and they don’t check for that sort of thing during the annual inspection you could probably run it. But not for interstate use.
    I know for sure if you were to go to Ontario, Canada and got inspected they will pull the plates off the truck and have it towed.
    flood Thanks this.
  4. flood
    flood Road Train Member
    4,168
    4,046
    Dec 25, 2010
    Sorry but that truck is 100% illegal..
    Will you get caught..? Don't know but the fine is BIG and you could lose the truck
  5. AModelCat
    162,859
    If the VIN doesn't indicate it is a glider then its most likely just a truck someone swapped an older engine in to. Unfortunately doing that is illegal.
    Vampire Thanks this.
  6. Phantom307
    222
    210
    Jul 5, 2019
    Cheyenne
    OK thanks yall, thats why im a member in this forum! I had a feeling that was the case but ive been seeing alot of these Shady Tree Gliders lately. I had to know, but it makes plenty of sense otherwise everyone would be doing it. By the way, he told me hes done 100,000 miles with the truck and its been fine, i guess its just a matter of time before he gets his cheeks busted.
  7. Sons Hero
    Sons Hero Road Train Member
    2,857
    29,165
    Jan 8, 2021
    Indiana
    You would be fine running that truck. I know a guy, I’ve hauled for him before, that buys brand new trucks, delete them right off the bat and he runs all over the place, including California. He has never had a problem. Average DOT has no idea what the mechanics of an engine even are, and if it says Certified Clean Idle on the door, that’s all he will notice
  8. Long FLD
    Long FLD Road Train Member
    12,685
    52,855
    Mar 4, 2015
    The chances of getting caught as a one truck guy are slim. I’d be more worried about the shop that did it and what all the wiring and everything looks like. You could end up with a hack job that could turn into a nightmare down the road.
    Vampire, Northeasterner and Sons Hero Thank this.
  9. Sons Hero
    2,857
    29,165
    Jan 8, 2021
    Indiana
    Like this? Lol
  10. pavrom
    pavrom Road Train Member
    3,208
    7,376
    Apr 29, 2012
    NE illinois
    I have 3 repowered trucks like that , inspected 25 times and after probably million miles never had any issue with dot
    Vampire and dirthaller Thank this.
  11. pavrom
    3,208
    7,376
    Apr 29, 2012
    NE illinois
    .. one of them is 2013 cascadia
