Glue between shims for fuel tanks
Discussion in 'Peterbilt Forum' started by Muddys, Mar 10, 2014.
  1. Muddys
    Muddys Bobtail Member
    Hi, does anyone know if both sides of the shim between fuel tank and strap shall be glued, or only against strap, on a Pete 379?
  3. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    910
    Mar 16, 2013
    What do you mean by shim? I've drove 379s all my like and never seen a shim on the tanks. Are you talking about the rubber piece between the band and the thank? If so put the raised edge around the side of the tank band and lat it on the inside then tighten your band back up.
  4. Muddys
    Thanks, yeah they might use rubber on later models. However, on my 379 from 88 it seems to be some syntetic band that was glued onto the bands. I'm changing the bands with some special made ones and will use rubber, but uncertain if glueing is neccessary.
  5. snowwy
    snowwy Road Train Member
    20,527
    13,263
    Jul 6, 2009
    glueing isn't necessary. but you can if you desire.
  6. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Muddys Thanks this.
  7. mark2014
    mark2014 Bobtail Member
    4
    you can also purchase the rubber webbing for the tank straps from your local Peterbilt Dealer.It works and lasts much longer than the cloth webbing w/glue and slips right on the straps.
