Go ahead and laugh
Discussion in 'Questions From New Drivers' started by Arizona Man, Apr 19, 2018.
  1. Arizona Man
    Arizona Man Bobtail Member
    36
    18
    Mar 9, 2018
    Just wrapped up my training at Knight Transportation not that long ago. We where all trained on manual transmissions. They where Eaton Fuller . Reverse was to the top left and low to the bottom left then four gears with a splitter after fourth then five through eight. Is it an eight,nine or ten speed.
  3. MACK E-6
    48,836
    226,009
  4. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,757
    Sep 20, 2014
    So eight gears plus low plus reverse? That's a nine speed.
    Roger McG and Bean Jr. Thank this.
  5. Brickwall
    Brickwall Light Load Member
    292
    381
    Jan 30, 2018
    Hahahahahahahahahshahahahahahahahah
    9 speed.
  6. Brickwall
    292
    381
    Jan 30, 2018
    Stevens blocks off low gear, and calls it an eight-speed, because they're retarded. It's still a 9
  7. ChaoSS
    3,338
    6,757
    Sep 20, 2014
    A thirteen speed is the same but 5 through eight can be split. An eighteen speed is the same but they can all be split.
    By the way, you didn't have a splitter, you had a range selector.
  8. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    When you're up shifting and leave the low side (move the selector) do you come to you and down or to you and up. To you and down (where Low is) then you have a 10 speed but if you go up then you have a 9 (which really is 8 + a "Low")
  9. Brickwall
    292
    381
    Jan 30, 2018
    What? That would be a 10.
  10. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Why in the world would they block off the low hole?
  11. joesmoothdog
    joesmoothdog Heavy Load Member
    737
    1,144
    Aug 5, 2013
    OTR
