The plan is to take an uber up there and drive it back.
Have experience driving a 10 speed tractor trailer. Is it pretty much the same thing?
Going 150 miles to pick up a manual car. Never driven a manual car. Will I be okay?
Discussion in 'Experienced Truckers' Advice' started by longhairdontcare, Jul 16, 2022.
Page 1 of 4
Pretty much,you have to give it a little gas as you let the clutch out.
If it’s new enough it may have hill assist so you don’t roll back and may even give it gas on it’s own.
No double clutching need.Last edited: Jul 16, 2022
Bean Jr. and Another Canadian driver Thank this. -
Correction, double clutch not required, but single clutch it at the minimum, EVERY SINGLE SHIFT
Car transmissions have synchronizers, no clutch use, youll destroy them in short order, you may be able to still shift like normal, but with no syncros, no one else can drive your car.
Bottom line, double clutching it (meaning a double stab, one clutch out of gear, one clutch into gear) is usually recomended big truck or little carBean Jr. Thanks this. -
In a car you just hold the clutch all the way down. Super easy. You can technically double clutch it too but you’re not supposed to.
Don't double clutch.nredfor88, Bean Jr., krupa530 and 1 other person Thank this.
Never heard of anyone double clutching a standard manual. Why would you?
BoostedTeg, nredfor88, Bean Jr. and 2 others Thank this. -
Single clutch, don't try to float the gears, give it gas as you let out the clutch. No splitter for high gears. Lol
BoostedTeg, tscottme, Texas_hwy_287 and 4 others Thank this. -
I used to float the gears in my old VW Bug. Don't know if you can do that in newer manuals.
Bean Jr., LtlAnonymous and Boondock Thank this. -
I didn't know people are actually using a clutch in a semi.
And they're double clutching to boot.Roger McG, tscottme, krupa530 and 1 other person Thank this. -
I have a Jeep with a manual. I sometimes would 'practice' double clutching with it. I know it is very different with a truck verse a 4 wheeler, but practicing on my Jeep I think helps with getting used to the rhythm of double clutching.
That said, for a 4 wheeler, push in the clutch (no clutch brake in a 4 wheeler tranny) give it a bit of gas. Feather the clutch to get going. When changing gears, push in the clutch, remove it from the gear you're in and gently put it into the gear you want to go to. Once the tyranny speed and engine speed get close enough to each other, it will slip in gear. That's what the synchomesh does and why you don't need to double clutch. The synchomesh will get the different shafts inside the tyranny to match rpms so it will slip into gear. That's why you just gently put it in gear, it may not drop in instantly, may have to wait a second or two before they match up enough. Then once in gear, let the clutch out. A little practice and viola, it'll work just fine for you.
Hope that helps!
Page 1 of 4
