Going back OTR sorta
Discussion in 'Questions From New Drivers' started by jason73125, Jun 22, 2013.
  1. jason73125
    jason73125 Bobtail Member
    temple tx
    I need some advice. I drove OTR for a little over a year and then switched to a local job driving a 26 ft straight truck. I did that for 4 years and after a corporate take over I have become a casuality of the business. I got my foot in the door at another company hauling more marketing type stuff (that's the best way to describe it). The trailer im going to pick up was being used for a commercial shoot. Anyways im flying out Monday to California to pick this thing up and bring it back east. its been 4 years since ive driven a tractor trailer or even drove a stick shift my straight truck was an automatic. what advice can the more experienced fellers give me to reassure me that I still will remember what the heck im doing. this isn't time sensitive freight when I asked when they want this trailer back by they said I don't know whenever you can get it here. it should be fairly easy driving once I get on the interstate im not staying in truck stops ill be sleeping in motels along the way so parking shouldn't be an issue. my main concern is shifting like at what rpm am I supposed to shift at if I remember correctly it was like 2200 but its been so long. I have no clue as to the make or model of the tractor I just know its white has the company logo on the sides and where its SUPPOSED to be parked at. its been expressed to me that this trailer is one of the shot callers baby and im expected to treat it as if it was a newborn baby but if I can get it back safely there is plenty of work for me. to reiterate im mainly looking for advice on shifting but any advice is appreciated.
  3. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Generally speaking, wind it up to 1800-1900 RPM and grab the next @ 1400 RPM wind it back up and grab another.
  4. Crossroads
    Crossroads Light Load Member
    239
    236
    Feb 28, 2013
    Lumberton NC
    I was out 13 years and before looking for a job I called local companies and most wanted a refresher course. I contacted a local school and rented a rig and instructor, 2 hours for $200, before I started taking road tests. I found it helpful because the instructor pointed out bad habits I had picked up over the 20 previous years. I have seen refresher courses at community colleges for as low as $650 for 40 hours 4 days, you might consider one of these options
  5. Chinatown
    Chinatown Road Train Member
    75,108
    171,316
    Aug 28, 2011
    Henderson, NV & Orient
    It's like riding a bicycle. You will be OK after about 50 - 100 miles. The hardest part will be logging.
  6. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    It's not a race car, 13-1400 rpm is fine. No wonder you guys can't get any fuel mileage these days!!
    CenutryClass Thanks this.
  7. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    In low range I shift around 1300rpm and in high range I shift at 1600. When downshifting I let it drop to 1100-1200 before shifting.
  8. TheDude1969
    807
    823
    Jun 10, 2013
    Joliet, Il
    7.6 - 8.1 mpg every trip. You don't loose much mpg at higher rpm, you loose torque but gain ponies... do you start in first gear no matter the load too? It is a race to get 40 ton moving, and once you get speed then shift the sweet spots.
    Learn your rig, not what some instructor said.
    HotH2o Thanks this.
  9. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Who are you racing to get that 40 ton moving? What's the big rush? Do you think a few seconds or minutes make a difference in the Big Picture of life?
    What instructor?
    And yes, I think I do know my rig, been driving it for quite a few days now.lol
  10. TheDude1969
    807
    823
    Jun 10, 2013
    Joliet, Il
    I'm not here to argue with ya, and I'm sure you are a fine driver.
    Have you ever been behind a truck at red light and was so slow he was the only one to make it threw the light. It's happened to all of us, unless you are that driver. Its my thinking get your #### moving, the possible fuel savings is so small its ridiculous they even teach such BS.
    So I'm left to try and understand your thinking.
    1800-1900 RPM is no where near any red line I've ever seen, which is above the average sweet spot (around 1600 RPM). Then drops progressively well into the 1400-1600 sweet spot zone. I'd be more concerned about lugging the engine under load below the average torque range beginning at 1200 RPM. If you have a newer truck w/ real time fuel mileage reading, check it out.. You'll see what I mean.
    Finally I'm not trying to drive your truck, and didn't ask you for your input... I simply answered a question for someone else. If you have an argument against what I believe to be true, then I'll gladly read in a new thread.
    HotH2o Thanks this.
