Going from drum to disc brakes. Any suggestions are greatly appreciated
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Flexedbmw, Nov 21, 2022.
  1. Flexedbmw
    Flexedbmw Bobtail Member
    15
    9
    Oct 16, 2017
    A little back story, I have a 91 379 with 1.6 million miles on it. With Meritor for rear ends, gear ratio 4:10.
    Also, I do all the work on this truck myself.
    I am wanting to price out getting a cut off with everything I want on it vs just sticking with the rear ends I have now and putting money into them with the disc brake conversion kit, new bushings for the suspension, different pumpkins, ect... The issue I am having is I can't find a drum to disc brake conversion kit anywhere online. Maybe I'm not typing in the right info for search on google, who knows. If anybody can help me out on this, I really appreciate it. Thanks in advance.
  3. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    are there such a kits ? never heard or seen it
    tscottme and Bean Jr. Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,483
    6,526
    Aug 26, 2014
    I do not know about 1991 but the ones from the early 80's had different bolt patterns on the axle for the backing plates.
    Buy a cut off with disc brakes if you want to go that way.
    skallagrime, Oxbow and Flexedbmw Thank this.
  5. AModelCat
    159,641
  6. W923
    W923 Road Train Member
    1,345
    4,101
    Feb 28, 2022
    Why… the drums worked for the last 1.6 million?
    Sorry maybe my opinion is tainted with the 100% increase in maintenance when the buses switched from drums to discs. They were both hydraulic brakes so maybe that’s the problem. I know there’s supposed to be some advantages.
    I wanted to say I heard at some point that the conversion was 3-4k but I don’t know what exactly was involved or what rears.
    I wouldn’t think that a cutoff with the idea of cutting the frame would be worth it. I also hate the idea of cutting a perfectly good frame and welding it back together and I have been in the welding business for a long time.
    BoxCarKidd and Flexedbmw Thank this.
  7. Flexedbmw
    15
    9
    Oct 16, 2017
    I have a newer truck with disc brakes and fell in love with them over the drums. I think overall it's personal preference.
    Also the frame rails are twisted and really pitted and rusted in spots. The previous owner already cut the frame and rewelded it. It cracked on me. I'm looking at getting a brand new frame rails made. 300 in wheel base. The moter went out, which is what kicked off this spending spree, and I'm upgrading from a B model cat to an E model. Figure while I'm putting money into it, I'm going all what i want into it.
    W923 Thanks this.
  8. W923
    1,345
    4,101
    Feb 28, 2022
    I can understand that..have you priced the rails new makes me feel better about the cutoff idea. Maybe get one that’s really long and splice near the cab…that usually clears up the old age frame problems
    Flexedbmw Thanks this.
  9. Flexedbmw
    15
    9
    Oct 16, 2017
    I have priced a couple of companies that make them, I thought they said 15k to make and ship them to me. I don't remember if that was also drilling all the holes or not.
    W923 Thanks this.
  10. W923
    1,345
    4,101
    Feb 28, 2022
    I would think that’s with the holes drilled because I priced some about two years ago for a 250ish wheel base truck for around 6 k but that was just heavy spec blank rails
  11. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    Its gonna cost you 10 to 12k just to get the cut off glued on plus the cost of a cut off so your gonna have ruffly 16 or 18k then the cost of the motor swap in a 1991 with 1.6 milliin miles ...you must really love this truck
    Oxbow, BoxCarKidd and Flexedbmw Thank this.
