Going from Regional to Local...(Schneider)
Discussion in 'Questions From New Drivers' started by R00kie Trucker, Sep 20, 2012.
  1. R00kie Trucker
    R00kie Trucker Bobtail Member
    10
    Fresno, CA
    Does anyone know if Schneider allows you to move from regional to local? I was looking into going local at first but everywhere I would apply always wanted someone with OTR experience (1year) so I decided to start off at regional and maybe drive that for about 3 months. I big reason why I want to work for Schneider is cause I know they have a lot of local jobs as well. My goal is to drive regional for about 3 months, then ask them if I can move to local. Anyone from Schneider know if this is possible? I know Schneider local jobs want 1 year OTR as well but if im already working regional but only have about 3 months exp, would that matter?
  3. nikmirbre
    nikmirbre Road Train Member
    5,395
    9,675
    Jul 27, 2011
    High Point NC
    I used to be leased to SNI, it just depends on how bad the need is for local drivers. If you are near french camp I believe they run local railyard out of the french camp OC.....
  4. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Ok THIS is what I was told by Greenbay:
    I saw Schneider pulling for Ford. Daycab pulling a pup and dropping parts at the Ford house. Exactly what I would want in semi-retirement since dealers are closed nights and weekends so I called.......
    Gal told me I can't have that......I would have to give them at least 6 mos in the system for the right to even join a long waiting list. They considered their local work cream of the crop juicy stuff to be reserved for the upper segment of their fleet. ( Really? Upper segment? At SNBC ? )
    Now read my bio, I'm not doing 6 mos in anybody's system for any reason. I don't have to which is why I do a L/P deal.
    Ask your recruiter. Something might have changed or the area market might be dry. You could walk right in, I've seen that happen before, right place , right time.
    Just do it....
    JMO
    RALPHMANBEARPONY Thanks this.
  5. RALPHMANBEARPONY
    RALPHMANBEARPONY Light Load Member
    131
    99
    May 25, 2012
    CLEVELAND GA.
    First 6 mos. you gotta stay put where you hired in.Then,and only then..Your DBL has to okay your request to move.
    If your needed they can/will keep you,or put you on the s-list since you no longer wanna play there.
    Thats my best memory :biggrin_25517:
