going thru alot of front hub gear oil
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by B5love08, Mar 20, 2023.
  1. B5love08
    B5love08 Light Load Member
    68
    38
    Nov 20, 2019
    hello all, not sure if it's normal or not but i'm going thru alot of front hub gear oil. I don't see anything leaking but I feel like I'm popping the rubber plugs out and filling them up. Is this normal orrrrr?
    thanks
  3. JB7
    JB7 Heavy Load Member
    855
    1,382
    Dec 13, 2022
    Laurel, MD
    Disc or drum brakes? Did you look on the back side of the wheel and drum to see if there is oil there? If drum brakes there should be a backing plate that you can pull off and look at the drum and shoes to see if there is oil on them. If there is no leak what weight oil are you using? Make sure you are using the correct weight. Front hub oil has a service interval just like the trans or differentials.
    Rideandrepair Thanks this.
  4. Star Rider
    Star Rider Road Train Member
    1,536
    12,782
    Sep 23, 2019
    You have a leak, period. Gear oil does not evaporate.
  5. B5love08
    68
    38
    Nov 20, 2019
    I'm using 85w-140 gear oil. and I believe its drum front brakes. 1999 freightliner fl-112 is make and model. and I haven't had a chance to pull front wheels off
  6. AModelCat
    160,527
    If you're going through the amount you're saying you are, you should be able to see the oil literally everywhere from a mile away.
  7. JB7
    855
    1,382
    Dec 13, 2022
    Laurel, MD
    Maybe not evaporate like water but burns off or something. I worked heavy truck fleet and topped off many transmissions, differentials and front hubs that did not have a drop leaking.
  8. B5love08
    68
    38
    Nov 20, 2019
    Nothing on asphalt where it's parked
  9. AModelCat
    160,527
    You won't see anything on the ground, look at the backside of the tire, bet its coated in oil spray.
    Rideandrepair, B5love08 and D.Tibbitt Thank this.
  10. B5love08
    68
    38
    Nov 20, 2019
    I'll crawl underneath and take a look. Thanks
  11. SmallPackage
    5,535
    17,632
    Dec 20, 2019
    Marion Texas
    If its leaking that bad i’d think you can smell it before you’d see it. Hot used gear oil mixed with brake linings dust smells like you ran over a skunk and soaked in the juice. My dogs can sniff it out and warn of the leak. Lol!
    Rideandrepair, bzinger and homeskillet Thank this.
