Going to a Team Run - Tips, Ideas, suggestions?
Discussion in 'Experienced Truckers' Advice' started by ziggystyles, May 24, 2009.
  1. ziggystyles
    ziggystyles Road Train Member
    Hey all,
    It looks like in about a month or so...I'm going to run team. Basically my route is joining another so that driver and I are going to pair up as a team.
    Right now, Im home daily, but with this new run...looks like the mileage will basically double and Ill be away from home at least 13 hours...probably closer to 15-16ish. Could possibly be even more.
    Either way, basically looking for ideas here as far as anything team related...I know I'll need to change my driving habits, lol.
    Im trying to think about ...what to do in the sleeper, lol. Sounds dumb, but this is a situation where If I drive in the morning one week....Ill drive the first half of the route and then climb in the sleeper when I switch with my team mate. Well...then Id have to sleep or something from then on...and then Id get home in the evening, don't think I can sleep in the truck for that time as well as at home (wife)...and Id hate to be up all night at home too. Probably an easy solution here, just can't think of it.
    *I know I need to work on bedding stuff. Already have a sleeping bag I use for a blanket along with a few pillows. Might think about an additional foam rubber type of padding.
    *going to get a cooler and start planning on what I need to bring
    Any ideas out there?
    Thanks!
  3. ampm wayne
    ampm wayne Heavy Load Member
    945
    746
    Jan 13, 2009
    bloomington,in
    Do you know your team driver? I have done some team driving. My suggestion first thing you and your partner need to have an understanding on things such as smoking. You need to talk about the run. Have a game plan. Who is going to drive first. Where you are going to switch. Try to make sure you share the work. It will become a problem if one driver feels they are doing more work than the other. If you both understand the expectations you should be fine. Try to get a long. Even things like cell phone calls can cause problems.
  4. Against The Wind
    Against The Wind <strong>"The Freedom Man"</strong>
    91
    18
    Sep 22, 2007
    So. Calif.
    Ziggy the route you are describing is basically a long local route that can not legally be completed by one driver under the 11/14 hour rules. If I were you I would follow ampm's advice and get a set schedule with your co-driver splitting the work evenly. You guys really do not have to worry much about lack of sleep since you will both be sleeping each night at home, so when you go to the sleeper catch a nap and read a book, watch a movie or bring a laptop the rest of the time. This should be a piece of cake. Good luck.
  5. ziggystyles
    Ampm,
    I do know the team driver as he is currently the driver I bring freight to. He drives a day cab with a pup, but started off in the company with a sleeper and 48, so that change won't be a problem.
    I know he doesnt smoke, although I sometimes do if Im running at the complete opposite time of day that I normally run...usually smoke Swisher Sweets lol....but its not a habit. Haven't done that in 6 months anyways.
    I've already sort of planned out the run. It could range from 800 on the interstate to 680 on Interstate and other highways. The shorter run is what we will probably run until winter, and then we will take another route home which will be 735 miles. Also...I figured that we would simply switch where the mileage is divided in half, so I drive half the miles and he drives half. The only downfall there is that, at that town, if I drove the first leg, I would have delivered 8 stops and he would only have 3. He said we could just do it that way as he doesnt like mornings, but I pointed out that its not really fair for me to deliver most of the freight either and he acknowledged that. So I think we will switch weekly. I drive in the morning one week, and the next, he drives the morning.
    I think Im going to bring up that we need to probably practice our shifting over the next few weeks before we become a team so we aren't jerking the other guy around in the bunk.
    Yeah this is where Im pretty much stuck at. Need to figger out what to do in that sleeper. maybe take a cat nap or something as I don't want to be up all night at home. Think Im going to try to find a bunch more stuff to listen to, maybe some audio books or something.
    We have a laptop, but thats the wife's, and its kind of a junker anyways. 2 years old and the battery is dead, and the power adapter (both of them) are also junk...have to make sure they sit a certain way, otherwise the laptop gets no power...a sudden jolt will kill the power and after a minute, the laptop dies...so that wouldn't work in the truck. That and the fact that the adapter gets to 160 degrees...eek!
    I guess the main sucky part here is that Im hardly going to see my wife...will need to figure out if this is going to work or not.
  6. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    You can buy a dc cig charger for about 50 bucks. They do not get as hot.
  7. PINEAPPLE
    PINEAPPLE Bobtail Member
    15
    May 4, 2009
    SoCAL
    Before leaving a truck stop, rest area or dock. Be sure to check the sleeper for your team driver. So easy to leave a co-driver behind thinking he's asleep in the truck. I ran teams for two years. We had a game plan and stuck with it. As soon as I was done driving and the other took over. We would talk for a few minutes then I went straight into the sleeper. Time alone behind the wheel and less contact with your co-driver, worked the best for us. To this day, we have been best friends for the last 20+ years. I have seen a few times where both driver and co-driver got out and traded punches. Interesting to say the least. :biggrin_25512:
  8. DoubleDear
    DoubleDear Light Load Member
    272
    135
    Jan 28, 2009
    Harrisburg PA
    Yes! Change your socks everyday!
  9. ziggystyles
    Well Im going to be home daily, so that wont be a prob; although I think I will bring some extra clothes in the winter time in case we get stuck somewhere.
    I dont know why I typed so much about the laptop, lol. It's the wifes so I wouldnt want to bring it along with me anyways...thats what she uses at home to surf the net and all.
  10. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    Start planning now on where to dispose of the body. :biggrin_25523:
  11. WhiteHawk
    WhiteHawk Bobtail Member
    27
    9
    May 21, 2009
    Nashville, TN
    I've been needing to get this off my chest since 1996.
    My first month after training, I ran team with a driver I met at the school. I was 29, and had about 8 years of experience racing sports cars. Baker was 23, fresh out of the Army where he had experience driving big military equipment.
    First off, we had different philosophies about driving and money. Ryder gave us plenty of time to drive the speed limit and make the runs, so I drove the speed limit (or less, if conditions required it). He was hell-bent on squeezing every penny and mile out of every hour that he could. He stuck his head out of the sleeper once in Ohio and yelled at me for still being in Ohio (55mph limit for trucks). I stuck my head out of the sleeper once in Pennsylvania to find us rounding a blind curve on a backroad too fast and finding the road blocked by a road construction crew.
    Also, thanks to years of racing, I drove very smoothly. The better your vehicle is balanced, the more traction you have for things like braking. My team-mate slung the truck all over the place, tossing me around the sleeper and preventing me from sleeping. And he wouldn't listen to me because he was 23, fresh out of the Army, and knew everything. After a month of that, I knew I had to run solo. When we got back to the terminal one night, I surprised him by asking the dispatcher for my own truck.
    My old teammate ran solo for a few weeks, then teamed up with an old Army buddy of his. I saw him once in a while, and one time he was worried that Ryder was going to find out about the three speeding tickets he had earned since we split. Yes, he got them in the truck. But he was happy with his new teammate, as they shared the same philosphies for driving and money. Meanwhile, life was good for me in the slow lane. I made more money than I had ever seen, and slept like a baby in my parked rig.
    A few months later, I was doing my paperwork after a run and the fuel jockey said "Hey, when you started here, weren't you teamed up with Baker?"
    "Yeah."
    "What was y'all's truck number?"
    "535. Why?"
    "Want to see what's left of it?"
    Baker and his Army-buddy teammate were bringing a backhaul of bleach from Texas, made it about ten miles from the Scottsville terminal where we were based, and failed to negotiate an S-curve, rolling down a hill. His buddy was driving, and Baker had to be cut from the sleeper. Both of his wrists were broken. I don't remember the extent of his Army buddy's injuries.
    Needless to say, Baker didn't drive there again. Probably didn't drive anywhere after that. Ryder wouldn't even let him be a yard jockey. Same for his buddy. I'm glad I wasn't around Baker's house when he told his wife and daughter.
    So if running team, talk about everything first. Find out what he drives like and see if you'll be able to sleep through that. Take an honest look at your own driving too. If you're both slow, smooth and professional, that's the worst part out of the way.
    Trucking_mom_mom Thanks this.
