Going to Army Base (Tobyhanna, PA)
Discussion in 'Questions From New Drivers' started by Mohtrucker, Jan 4, 2020.
  1. Mohtrucker
    Mohtrucker Light Load Member
    135
    188
    Oct 20, 2019
    I'm delivering a load to this army base in tobyhana,pa on Monday it's my first going to a military base so what should I expect?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,731
    Jan 30, 2010
    keep stroking.
    Not a base, it's an depot. Security will check your truck out with sniffing dog and check to see if US citizen. Other than that your good to go.
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Remove dashcam if you have one.
  5. 062
    062 Road Train Member
    6,232
    33,517
    Oct 20, 2013
    If there’s any possibility that you have a warrant DO NOT GO.
    x1Heavy and bzinger Thank this.
  6. Fredterbert6666
    Fredterbert6666 Light Load Member
    67
    142
    Nov 27, 2019
    Why would he have a warrant and not know about it?
  7. Moose1958
    Moose1958 Road Train Member
    15,185
    33,451
    Dec 17, 2010
    Williesburg, Virignia
    If you are going onto a DoD base you can expect to be directed to an inspection area. They will inspect your truck inside (maybe) and under it. They might run you(depends on the mission of the post and availability of getting the data) on the NCIC. Most of the time these checks take a short time. Also be aware most DoD bases have Gates that are designed for this traffic. Call ahead if you have never been on post.
    D.Tibbitt Thanks this.
  8. The Veteran
    The Veteran Light Load Member
    50
    101
    Jan 2, 2020
    Have your current US drivers license ready. You will have to go inside the security office and get a pass. Fill out a form, they take your picture and answer stupid questions then your on your way.
    If your not a US citizen, dont bother going in there. I've seen several of those foreigners setting there with loads on and cant get in to deliver. I've been asked several times and I always respond, NO I WILL NOT DRIVE YOUR TRUCK IN THERE TO UNLOAD IT FOR YOU!
    12 ga, tscottme and D.Tibbitt Thank this.
  9. bzinger
    bzinger Road Train Member
    16,613
    65,931
    Dec 10, 2014
    omaha , ne
    Must be lots of people that dont know cause I used to haul fuel into offutt AFB and they were always hauling people to jail from the gate there .
    tscottme, D.Tibbitt, x1Heavy and 3 others Thank this.
  10. Moose1958
    15,185
    33,451
    Dec 17, 2010
    Check out their WEBSITE, This WEBPAGE has some phone numbers if you have any questions!
    tscottme Thanks this.
  11. Moose1958
    15,185
    33,451
    Dec 17, 2010
    The Wing Commander there has changed the base firearms policy. I highly recommend due caution if you are armed.
    x1Heavy Thanks this.
