Good m-b hf/vhf rig?
Discussion in 'CB Radio Forum' started by Rook, Jan 24, 2007.
  1. Rook
    Rook Light Load Member
    140
    10
    Sep 22, 2006
    Texas
    I was looking for opinions on a good multi-band HF/VHF rig for my rig? I was looking at one of those all band mobile antennas like the [FONT=Arial, Helvetica, sans-serif]COMET ANTENNAS UHV-6[/FONT]. How do those antennas work? One connection? Do they require a tuner?
  3. kc8vje
    kc8vje Light Load Member
    138
    15
    Jan 8, 2007
    East Point, KY 41216
    I recommend the Yaesu FT-857D. I have 2 of these radios and like them very well. My second recommendation would be the Icom IC 7000. I got to play with one of these units last week and it was awesome. This will definitely be my next radio.
    As far as antennas go. I use the Yaesu ATAS-120 for mobile right now. However, later on I'm going to get either a High Sierra Sidekick, or a Bandhopper.
  4. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    I have used the 857d and the icom 706 and both are good radios. i use the 857d over here in Iraq and it does a fine job on a G5RV and a tuner also. I ran a screw driver on the truck and still have it at home made by NO5E and it will last for ever. But if you want one that will last fo ever and give you no real trouble the Band hopper is the way to go. If you are going to run any power which i recomend if you want to work 75 or 40 mtrs then deffinatly the band hopper it will take legal limit and never give you any problems.
  5. kc0rey
    kc0rey Medium Load Member
    536
    85
    Jul 5, 2005
    Macomb, IL
    I too like the FT-857D and it is cheap right now at $695 and comes with a free remote mount kit.
    I can't comment on the antenna and most of your all banders use 2 or more antenna connectors as well.
    I relied on 2 seperate antennas. One for HF through 6M and one for 2M and 70cm.
