Good mechanic near Freemont, IN?
Discussion in 'Ask An Owner Operator' started by RERM, Aug 28, 2014.
  1. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Anyone know a good Cat mechanic near Freemont, IN?...need to do a Pre Purchase Inspection on a KW...
  3. 201
    201 Road Train Member
    12,342
    25,233
    Apr 16, 2014
    high plains colorado
    Hi RERM, did your mechanic bail on you? I see your last post you said your mechanic was going to check it out. If the engine only has 100 miles from rebuild, there should be papers on that, no papers, no deal. A short ride will tell you a lot, however trucks behave and sound different with a load on. You may not hear a bad bearing until you have a load on. Oil from the axles and trans should have no metal shavings (like metallic paint), nothing coming out of the air tanks. When it's running, grab the steering shaft and turn it, watching the steering gear for worn parts. Price seems fair and KW is a great truck.
    Battle Born Thanks this.
  4. 209218chris
    209218chris Bobtail Member
    22
    Aug 22, 2014
    stoops freightliner behind t/a or petro which ever. good people
  5. 209218chris
    22
    Aug 22, 2014
    seen a lot of fresh rebuilds fail n the first 1000 miles
  6. RERM
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Yes, "semi" retired, he's too busy to leave the shop, I made an appointment at Palmer Kenworth though, I'll take it to them....
