I have been confined to the Smelly sleeper birth and would like to start an easy to search thread about best practices and tips.... this could be backing up... qualcom...refer unit.Western weigh stations...reading signs...holding the wheel during wind... and anything you experienced guys could collaborate and we rookies could ask...
Please someone begin talking about signs.... how come even thow I am freaking out about them they sneak on me... I am not blind and have a decent gpa in two degrees so I can read...is it because I am stuid.
Good practices and tips from otr drivers...please
Discussion in 'Prime' started by TooGroovy, Feb 25, 2013.
Page 1 of 10
Watch what lane your in your an easy target for a inspection if your not in the right lane. Also when your behind another trk be cautious when going thru a intersection because you wont be able to see the signal till your halfway thru it because of the trl in front of you blocking it.ive seen many accidents because of this scenario. .
TooGroovy and superpet39 Thank this. -
I have only been doing professional driving. ..or attempting to...for three days and it seems that the signs come in clusters...am i correct...is there an order to them..is there a general area...I dont mean the side of the road...but before an exit or after... any thoughts...
Stay out of the left lane in California!
One good thing to remember is the exit signs warn you at lease two miles ahead of your turn an easy thing to do is write down your exit number on sticky note and put it on your dash
TooGroovy Thanks this. -
What is the real deal with downgrades.... i was told you put in lower gear at school andcwhen I did my trainer began cursing me out and calling me names... it wasba six degree and it was looooooong....then I put the engine brake and cc when it did nothing I iput the brakes... no matter how I put the hrakes I got yelled at... what is the real deal we weighed 76000
Some states have exits as mile markerssome states make no sense on exit numbers.yes they come inclusters they do that you have more than one reference whe. You use the exit. And yes if needed downshifftig usually occurs beflre the downgrade...just indure your trainer do what he asks cause your time with him is short soon you will be onyour own with him just being a faded memory..
kerosene jockey and TooGroovy Thank this. -
At the shipper.... I was turned around and it became a mess....first they said ...five singles and 17 pallets....then they ran out of boxes and they began with sacks and it became pallets of a different unit count because the sacks were bigger.... I had never been inside a warehouse shipper before and did not know what I was counting... my trainer was in the sleeper. ..the guys in the warehouse told me that...this is how its done...it became a mess and I know I was dumb....should I have stopped the loading....
I have never counted anything while be loaded or unloaded nor have I had problems when the load was short or overage thats there problem (shippers and consignees) your job is to drive you need to be in the cab resting for the next load.i know trucking companies and shippers say its the drivers responsibility to count the load during the loading process ut its never inforced it would be just a waste of time..
If it's a driver count load (SLDC) you need to be on the dock to count it. When you sign the bills for one of those loads, you are verifying that the count on the bills is the count that was loaded on to the trailer. If for some reason you get to the consignee, and they didn't load the correct number of cases, there will be a cargo claim on the load and you will be responsible because you didn't count the load, but still signed for the count.
Page 1 of 10
