good ratio for mpg
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hellpatrol, Dec 29, 2016.
  1. hellpatrol
    hellpatrol Light Load Member
    221
    172
    Apr 22, 2013
    I have a 2013 389 with a isx 600hp, 18 speed and 336 rears. I was told the 336 sucks for fuel mileage AND climbing hills. What would be a good one?? I thought the lower the ratio the better the mileage. I know it didn't do any good for the hills, but I hoped the hp would overcome that. Any info would be good, thanks.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    Could always drop a gear and see how it goes.
    If you are loaded light it may be okay, heavy you may need a few more rpm.
    I changed the gears on a previous truck, cost just over $5,000. Hard to make that money back at today's fuel prices. But I went from 3.58 to 4.10 as I was moving up to 140,000 lbs. After when I went back to 80,000 lbs my mpg improved 0.6 mpg over the 3.58, but I had to keep it under 62 mph.
    Oxbow and rabbiporkchop Thank this.
  4. 51.50
    51.50 Heavy Load Member
    894
    1,942
    Jan 20, 2016
    Salem Oregon
    Freightliner Century with Series 60 pre EGR Trans: 10 speed Axle 2:79 ratio with 22.5 low pro tires 7.3 mpg measured over 50,000 miles included loaded heavy and light and mt mileage.
  5. hellpatrol
    221
    172
    Apr 22, 2013
    my weight usually around 40k-60k total. Yank doubles during the night. weight will vary, but never near 80k, always less. That's why I thought the 336 would be good, plus the 18 speed and the 600hp. would like to keep the speed around 65-70 max.
  6. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Its all about torque and hp. If your working engine its using fuel. If it acts like its happy and not working hard then go with lower gears. All engines have a sweet spot-find it and work from there.
    Diesel Dave Thanks this.
  7. hellpatrol
    221
    172
    Apr 22, 2013
    I try and keep it between 1,200-1,400 rpm on flat ground. Going up the hills, 1,700 to shift otherwise nothing about 1,500. Keep the boost below 30 psi if I can unless other reason dictate. I figure the boost is my money gauge. Keep it down and keep the cost down.
    uncleal13 Thanks this.
  8. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Halfway between peak HP and torque at 65. If peak TQ is at 1200 and HP is at 1600 somewhere between 1350 and 1400 is where you'll want to be. Also depends on the rubber. I went from tall 24.5s to 22.5lp rubber and I turn 1450 at 65 now. Which used to be about 72. Same RPM same weight mpg difference is about oh 1.25mpg.
    Mpg is a difficult game and you have to understand the dynamics involved. I have pretty tall gears for running 90k gross (3.42) but I run a lot of stop and go and don't have too many steep hills. Truck never sees the better side of 65 loaded unless it's headed down a hill. Average is between 6 and 6.5 every month.
    For what you do your 3.36s are probably fine unless you're having to drop gears when you pull hills it's fuel out the stack might be better suited for 3.55s if you're having to drop and run hilly terrain which is where you'll burn a majority of your fuel.
    hellpatrol Thanks this.
  9. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    I ran 3.70 on 04 ex-Kinard t600, low pro 24.5, 4 row radiator, bar plated air cooler, 6nz file 500 hp, 10 sp standard. Avg load weight 30-40k lbs. Getting between 5.7-6.5 mpg when driving 65-68 mph around northeast-southern region.
  10. 51.50
    894
    1,942
    Jan 20, 2016
    Salem Oregon
    I got the best mpg from an FLD 120, engine M-11 Cummins, RTX 10 speed, 3.91 axle 22.5 LP tires
  11. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    M11 was one of my favorite engine to play with when I was at training at fxf on doubles. Their pre 2000 daycabs had that m11 on them.
