Good rear axle ratio?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Slingingbullets, Sep 22, 2014.
  1. Slingingbullets
    Slingingbullets Bobtail Member
    10
    Sep 19, 2014
    I'm looking at at KW T680 with Cummins ISX15 rated at 485hp with 13spd and 3.36 rear axle. I typically pull avg of 37-41k. I run mostly midwest with some runs going through the appalachians. I'm wondering if that's going to be a good balance of mpg and pulling power. I would love to get 6.5ish but still take the hills pretty well.
  3. Pahrump
    Pahrump Medium Load Member
    good ratio sweet spot is around 1500 to 1600 rpm
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    what speed do you plan on running? unless you go 70+ you would be better with a 3.55. What kind of tires? Is your 13 a double over or single over? Without the above info, no one can make a 100% accurate recommendation. Short rubber with a 3.36 is roughly the same as a 3.55 with tall rubber, although id recommend short ruber with a 3.55 unless your planning on going 70 all the time.
  5. Slingingbullets
    10
    Sep 19, 2014
    Tires on it are 275/80R22.5 , tranny is 13 double over, 65-68 mph ave cruising speed
  6. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Slingingbullets Thanks this.
  7. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    what rpm do you want to cruise at...i feel 1600 is a bit high for that motor.
  8. Slingingbullets
    10
    Sep 19, 2014
  9. mattbnr
    mattbnr Road Train Member
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    Slow down to 60 and you'd gain 1 mpg right there with no changes. Every 1 mpg over 55 you lose .1 mpg.
