governed or not governed
Discussion in 'Experienced Truckers' Advice' started by covenantbiker, Dec 1, 2010.
  1. covenantbiker
    covenantbiker Light Load Member
    217
    71
    Jun 28, 2008
    Conroe, TX
    Not sure if this goes in the right forum so if not, I guess it will be moved.
    I know that the majority of trucks out there are governed. I am a trucker but had a question about power between governed and not governed.
    Depending on the weight, (this might be stupid) does a non-governed truck have more power pulling hills? Or does this also depend on the size of the motor.
  3. Sweaty
    Sweaty Light Load Member
    75
    60
    Jun 1, 2008
    Decatur, IN
    I have driven both, and when heavy on hills I cant tell a difference in the power, both slow down.
  4. ChromeDome
    ChromeDome Road Train Member
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    Your governor will not effect hill climbing directly. It will lower your speed at the bottom of the hill, so you will have to shift sooner while going up. Since you are starting at a slower speed. But does not effect your trucks power.
    On the other hand many company's get the trucks power turned down when they get them. They lower the torque and HP to lower than manufacturers levels.
    This will cause a lack of pulling power on hills.
    rocknroll nik and kenn2632 Thank this.
  5. orion3814
    orion3814 Medium Load Member
    490
    110
    Dec 31, 2008
    tulsa, ok
    you also have some trucks like the ones in our fleet that are rpm governed at 1500 rpm im lucky mine isnt but that also imo has a lot to do with hill pulling capabilities..
    my truck will run up to 2500 rpm its nice cause although im runnin 65 which is our governed speed i can shift 1 down b 4 the bottom of the hill and be able to hold that gear a lot longer without shifting and be able to make it over most small med hills without having to shift any further...
    i love my cat.... lol.... thing seems to pull balls out compared to the cummins and detroits in our company..
  6. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    It will if you have a 65 mph governed truck & the driver all ready has hit foot to the floor.... There won't be any room to spool up the turbo to pull the hill
    jakebrake12 and orion3814 Thank this.
  7. ChromeDome
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    That is true as well Mr. Red.
    Actually I remember making that same comment in a thread a long long time ago.
    It just did not quite fit the question, so I left it out. Did not want to confuse anyone.
    I have a tendency to do that on a regular basis when I start to get into mechanical crap on here lol.
  8. terrylamar
    terrylamar Road Train Member
    1,023
    368
    Oct 8, 2006
    Austin, TX
    You could down shift.
  9. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    So your going to put that kind of strain on your transmission?
    Lets see.... Your governed at 65 mph. Your traveling at 65 mph. If you downshift, the only thing your going to achomplish is possibly exploding your transmission.
  10. terrylamar
    1,023
    368
    Oct 8, 2006
    Austin, TX
    Well, I would wait until my RPM's were down. You do what you want, but then my truck isn't governed, or, I should say, it is at 127 mph.
  11. orion3814
    490
    110
    Dec 31, 2008
    tulsa, ok
    turbo's bahahhahah couldnt help it bud:biggrin_25522::biggrin_25522:
