GPS Unit causing Check Engine Light on 2016 KW T-800
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TankerJim, Dec 31, 2020.
  1. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    If you bought the truck used, better check if all previous wiring for qualcomm etc. were removed.....
    spsauerland, Heavyd and Goodysnap Thank this.
  3. TankerJim
    TankerJim Bobtail Member
    9
    5
    Dec 31, 2020
    First of all, I do appreciate your time. The first answer made a few unfair assumptions and was a bit snarky, so that prompted my response. again, thanks.
    So, here's a few more facts:
    1) The unit is a 2015 T800.
    2) The same GPS module has been on that truck for about 2 years and been otherwise flawless. To date, if we plug it back in it works fine for a while, then we start to get the data bus errors. They can be any kind of error - at first we were seeing DEF sensor error of some kind. It's been a while and I don't recall the specific error at the moment, but it was enough for Kenworth to replace the DEF sensor part - whatever it was. Honestly, I don't think it had even failed, I think the KW guys swapped it out because the error code told them to and it was still under warranty. Somewhere during the repair, the GPS unit was unplugged, so the road test after the repair went fine. We plugged the GPS unit in a few days later and no problems occurred for about a month. Then we started getting errors again. It was the DEF sensor one time, then it was a few other unrelated errors, like coolant level low (coolant was fine), and others. We unplugged the GPS unit, and magically, all the new errors stopped occurring. We plugged the same GPS unit into another truck - 2016 truck I believe - and it worked fine. No errors at all. We also put the same unit into a 2019, and it worked fine. Other GPS units are in various other units all T-800s from old (1997) to new (2020) and we have not seen any similar problems except on a 2016 that kept having speed sensor problems, but in hindsight I'm wondering if that was a malfunctioning GPS unit also causing the error. That particular truck is gone now, so we cannot test for that.
    3) Sitting here at home, I'm not sure if the problem truck is running 250 or 500K, but I'll find out on Monday. I was not aware that they had changed the data bus speed and that is certainly something to look into, although the GPS unit worked great for almost two years in that, and continues to work fine in other trucks, so I'm a bit at a loss on that. It could be that it was capable of both speeds and somehow has lost it's ability for the slower speed.
    4) Codes were all over the place. The speed sensor error was a "shorted speed sensor" one time. Another time an error told the ECM that the truck was doing (something like) 150 miles per hour and this caused the ECM to disable the throttle because that was obviously above the programmed maximum speed. Clearing the codes solved the problem temporally until it happened again. Kenworth replaced the Bendix Computer that time claiming that the Bendix computer was bad. Now, I'm doubting that also. I think the GPS unit was somehow screwing things up.
    5) We've checked all the pin-out of the cables. They all line up the proper +12, -12, Data, etc. lines.
    One thing that bothers me is that the units are packaged with OBD2 connectors and the GPS folks ship an adapter cable that goes from OBD2 to J1939. I didn't think a OBD2 device was compatible with the databus on the larger trucks, but all three GPS vendors I have spoken to assure me that they are and that they have "1000's" of units in place working fine.
    It continues to be a mystery. My next step may be to put a logger on the truck and watch the databus constantly, recording every bit of data and see if I can see whats causing the error. I've done this before and the amount of data in an 8 hour shift is amazing. Thousands of pages.
    Anyhow - that's my long-winded explanation. Thanks for your time.
    spsauerland Thanks this.
  4. TankerJim
    9
    5
    Dec 31, 2020
    Thanks. All trucks were factory delivered to us. I miss the days of non-electronic engines. I've got a Big-Cam 400 in an old yard-rat truck that is still purring like a kitten. Starts ever time. No regeneration. No DEF. It will probably be working well after I'm dead and gone. These new trucks with their numerous computers suck.
  5. TankerJim
    9
    5
    Dec 31, 2020
    Yeah, we wired it according to the KW instructions. We did not use the diagnostic connector.
    I was not aware of the baud rate change, so that's something that we will be looking at, however all of the units have been working fine for just under two years or so, so I'm assuming they are somehow auto-adjusting to whatever baud rate they are connecting to. As I wrote before, I'm wondering if the comm chip in the GPS unit is failing now and is having periodic problems with comms and somehow screwing up the databus. The truck that has the most problem is a 2015, and the rest of the fleet is mostly newer and doesn't seem to be having any problems. A 2016 truck that we used to have was also experiencing problems, and I'm wondering now if that was GPS unit induced as well.
  6. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    All right, thanks, that gives us way more info to help with....stupid question...what happens if you take a 'know good unit " from another working truck and put it in this 2015? Same thing?
    I have seen something similar with a diagnostic interface being plugged in.....that was a CAN diag connector ground issue and the interface being plugged in reeked havoc on the vehicle.
    The other thing that might be interesting to know is if these GPS/Tele units self update [or if this one has been updated] as maybe the unit has been "adjusted" program wise for something newer?
    Hammer166 Thanks this.
  7. TankerJim
    9
    5
    Dec 31, 2020
    I'm not sure that we've tried the know good-unit thing yet. I'll add that to my list of stuff to do this week. Honestly, the customer service from Azuga was so piss-poor that we are trying out another vendor (GeoTab) and as soon as we plugged their unit into the 2015, the 2015 started throwing errors too. GeoTabs answer was "we have these in a ton of Kenworths, they all work fine." So, the question now is "what year Kenworth?" I guess.
    I'm also curious about the self-update issue. That's the only way i can explain why they began to fail after working for so long. My only other theory is that the units are just degrading and the comm chips are not working like they used to....but that's a bit of a stretch, they are not that old yet.
    I'll fill you in more as I learn more. Thanks for your interest.
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    What is build date? 2016 requires the Y harness to properly connect. We run Geotab and they have a specific harness for Paccar. I have had issues with a failed transponder and bricked trans ecm @ same time. Not positive which failed first. Newer VECU trucks we use the RP1226 connector to connect to data bus. Screenshot_20210101-194531.png
    QUALITYTRUCK Thanks this.
  9. Flint1
    Flint1 Road Train Member
    1,154
    9,880
    Sep 4, 2019
    Alberta
    I have installed hundreds of geotab units onto cat/Cummins/Mercedes/detroit/international engines (years from 96-2020) and have never had data line chatter issues. I have seen a damaged harness ground out or short j1939 and cause issues. Geotab implies their units are read only.
    I have seen operators disable the ability for the geotab to communicate on th j1939 by cutting the j1939 circuts in the t harness to the geotab.
    Geotab still functions using ign feed on the plug. It will also "wake up" as it starts moving.
    Cutting those circuts may make your ELD non compliant, but may prove whether or not the issue is a result of the gps
  10. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Here is Paccar recommended installation manual of J1939 third party devices prior to the RP1226 connector.
