GPS with Truck Routes
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by new bee, Mar 4, 2007.
  1. new bee
    new bee Bobtail Member
    4
    Mar 4, 2007
    Hello,
    I have a quick question. Are there any GPS units have Truck Route maps for the United States built in? Or can they be purchased or downloaded. I did an extensive Internet search, and I was unable to find any information on portable GPS units with truck routes. I know Laptop software is available, but I need a portable GPS unit. Thanks for your help and time.
  3. TNtrucker07
    TNtrucker07 Bobtail Member
    21
    Garmins (particularly the 2730, 2820, 7200 & 7500) have a truck setting that will (for the most part) keep you out of trouble. I bought one two months ago and I have found it accurate for low bridges and weight restricted roads but needs some work for local truck restricted routes. You will STILL need your Rand-McNally to suppliment it.
  4. new bee
    4
    Mar 4, 2007
    What Garmin model do you have? Do you know where on the Internet I can read up on models with ‘Truck Routes’? It doesn’t have to be Garmin, any brand will do just as long it is portable and not laptop software. Also which is the cheapest one with the 'Truck Route' function? You know as well as I, when you're first starting off cutting corners is very important when it comes to saving money. If you have any more hints, tips or any advise I would appreciate it. Thanks.
  5. TNtrucker07
    21
    I have the 2730. It runs about $500. The others run up to $1500. If you are going to go the GPS route, you do not need to go cheap -- you need to go reliable. If you cannot afford a good one, just stick with the ole Rand-McNally. You can search this or the other trucker forums under Garmin and find a lot of posts about them.
  6. CrewseMissle
    CrewseMissle Bobtail Member
    20
    Boothbay, ME
    hey, if you have a laptop there is a program called Copilot Trucks for laptop. Specially designed for truck routing. Has weight limits, low overpasses and routing for 53' trailers. I have the basic car edition and it works real well. But for 350 dollars you can get the truck routing software and a gps locater unit. As soon as I finish traing thats what I plan to get.
  7. Captain67
    Captain67 Bobtail Member
    8
    Cape Coral FL
    Not sure what you mean by truck routes.
    The big models 7200 & 7500 are designed for bigger vehicles - rv's and trucks.
    Google their names to get alot more info. And not sure what you mean by portable. Portable in the GPS world means handheld, as used by hikers.
    ALso look in the electronics forums below.
  8. shaken
    shaken Bobtail Member
    16
    6
    Dec 13, 2006
    Siemens VDO is supposed to be releasing a truck-specific GPS shortly. Right now its being tested in Europe
  9. Hitman
    Hitman Mr. Gamer
    2,465
    15,508
    Sep 5, 2006
    Tioga, PA
    I would assume, the type that you attatch to the windshield with a suction cup type device.
  10. new bee
    4
    Mar 4, 2007
    I laughed out loud when you compared the Garmin tech support to Dell tech support. I've been going in circles with dell for quite sometime now (what a joke), but that's a another story. You stated you had the Garmin 2730. Can you program your in own route so it will talk to you as it comes up on the screen? That way it's not how the computer wants you to go, it's how you want to go. Also where did you purchase your Garmin 2730? Walmart has that model for about $740.00 with tax and shipping. You stated that you payed about $500.00. Did you buy your new, used or refurbished? Thanks again for your help.
  11. new bee
    4
    Mar 4, 2007
    Please visit the Garmin Website they use the word 'Portable' as meaning Being able to take with you and not installed in your vehicle.
    "Our streetwise portable GPS electronics can guide you along the highways and byways — and down the beaten path as well — without the heavy price tag and restricting installation of standard automotive GPS systems."
  • Draft saved Draft deleted
