Gravel Guys making money??
Discussion in 'Ask An Owner Operator' started by jeremiahwagner33, Oct 2, 2014.
  1. jeremiahwagner33
    jeremiahwagner33 Bobtail Member
    I am new to this forum so if there is a related thread let me know. But my question is how do these seasonal gravel haulers make their money and how does their general operation work? I live in an area where there is about ten different gravel pits or ready mix plants in the area and I see an insane amount of guys with their own trucks hauling back and forth all day. How do these guys find work? Especially if there are so many of them? Do they make descent money? Is this something good to get into?
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Ya right. Cheapest freight out there. Ety 1/2 the time. Too many in it with ratty broken down former road trucks with over a million miles on them.
  4. Powder Joints
    7,569
    7,543
    Sep 25, 2007
    Rosamond, SoCal
    Really cut throat. All brokered
  5. Cat sdp
    Cat sdp . .
    20,879
    72,245
    Apr 8, 2012
    Orion's Belt
    Depends where you are....... Around here it's mostly direct work for the pits/quarries . And they set the rates.......
    The best places to work have very little turn over and you'll never live long enough to make the top of the list.......
    Going rates are like $70-80 per hour for a 4axle and maybe $100 for a 6 axle. Per ton rates are a crap shoot based off the hourly rates....
    It's a tough road and you aren't going to get rich......
    Hopefully we'll have a good season next year.......
  6. 201
    201 Road Train Member
    12,150
    24,803
    Apr 16, 2014
    high plains colorado
    Like others say, it's pretty cut throat. In Wis., it's usually bid on by owners of construction co.'s, and then they hire O/O's on a "as needed" basis, and it's usually the same guys year after year. Money is so-so, you don't burn a lot of fuel, maintenance is high and it's seasonal, and most of the guys go on hauling road salt for the winter, which, when I did it for a company, barely paid for the fuel. Good luck trying to get in on that racket.
  7. korky
    korky Light Load Member
    97
    56
    Aug 14, 2013
    AZ
    When I did it in Chicago for 8 years it was mostly through a company that you leased on to. They lined up the work and told you what to haul and where to take it. I did it from 1997 to 2005 when fuel was cheap. I was making anywhere from $500 to $900 a day but knew it was like that for only 6-8 months of the year and it depended on the weather as well. I also hauled the salt, but it didn't pay squat and you waited for hours to get loaded. Once the season wound down, I switched to hauling rail cans to get through to the spring. I still have a few friends that pull end dumps on the south side and they say its almost not worth it. Up by you might be better though. Maintenance and insurance is high but you don't burn a lot of fuel or need IFTA if you stay local. It was the most fun I ever had driving though.
