Grease coming out on S Cam side after greasing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Edjahman, Nov 29, 2020.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Hi.
    I kinda went crazy with the grease gun recently because I thought that you are supposed to grease the S Cam tubes until grease comes out on the slack adjuster side of the S Cam tube.
    On 2 axles I had grease coming out on the S Cam side causing a huge problem. I cleaned it up and that was a huge pain.
    Are there seals on the S Cam side of the tube? Did I just go crazy with the grease gun?
    I was under the impression that the S Cam side is sealed and that's not supposed to happen?
    Does it all need to be dismantled and new seals put in? I was trying to avoid pulling out the S Cam shafts but if it needs to be done I understand.
    Thank you!
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Just keep cleaning excess grease. Mine gets on the inside of brake shoe yes its a mess. Runs down. There is a seal but in my experience not quite like a tight oil seal. Wouldn't think you have harmed anything. I grease my own truck except when i get oil changed. Had to tell speedco not to grease s-cams as they over grease. Just a couple shots will suffice. Of course it depends length of lube intervals. I like to grease every 2 weeks. Some say thats to much. Also if the trk is in dust etc too. Just water, and salt water up north this time of year is bad also.
    Edjahman Thanks this.
  4. Edjahman
    648
    444
    Apr 2, 2013
    Yeah I like to grease my truck and trailer myself because I like to be in control of it.
    I run the southwest and avoid winter as much as possible.
    Thank you for your reply! I appreciate it!
    stillwurkin Thanks this.
  5. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    I may add a friend of mine says don't grease u-joints till you force grease out around the seals. I always have, since my dad taught me. Like 50 years ago. Still do. Never had a failure because of it. But it does sling out and make a mess. But he does it his way, i do mine.
    blairandgretchen and Edjahman Thank this.
  6. Edjahman
    648
    444
    Apr 2, 2013
    I definitely need to up my greasing skills.
    Thank you for the information!
    blairandgretchen and stillwurkin Thank this.
  7. AModelCat
    161,681
    There usually is a lip seal there. When the cam and bushings are new, there's very minimal play. As the bushings and cams wear, there gets to be some slop in there and that can affect the seal's ability to work. Personally if the cam and bushings aren't excessively worn I wouldn't go to the trouble of replacing those inner seals. Most cases you'll have to pull the hubs to get the cam out. I'd just continue greasing them regularly and just watch the inner part of the cam and stop once grease appears.
    With the u-joints I normally grease until I can hear them crackle, then slowly pump grease in until I can just see grease at each cap. That way I know each one has lubrication and there isn't a lot of grease getting slung around over everything.
  8. Edjahman
    648
    444
    Apr 2, 2013
    Thank you. I appreciate the information.
