Grease in trailer axle bearings instead of gear oil?
Discussion in 'Flatbed Trucking Forum' started by ichudov, Jul 7, 2018.
  1. Natedog1200
    Natedog1200 Bobtail Member
    14
    5
    May 23, 2017
    Inside looked fine, was my oldest tire and should have been rotated out last week. At initial look no obvious reason it was flat and yeah, I knock 'em pretty often so I know it was good at least midway through the day.
    Yeah I miss so much about a semi but won't go back till I have the funds to get my own and funds to keep me running. Was nice just pulling over and calling dispatch when I had a flat. Now it's rain, snow, both or 117° in phoenix and I'm out there doing it myself. The joys of having your own authority.
  3. Natedog1200
    14
    5
    May 23, 2017
    I checked hubs and lug nuts at 50, 110 and 200+/- mile intervals and no obvious difference in temps. Either way it's time to repack anyhow before summer. I tend to run quite a bit in phoenix over the summer whether I want to or not, figure it's better to have fresh grease when the temps are 110°+ regularly. Gotta get me an IR gun too when I get back. Someone mentioned earlier, that'd be handy. As for someone mentioned leaky seals, that was why I switched to grease, I will say permatex on outer surface of seal made a huge difference, couple seals lasted more than a year with no leaks but you never know when it's going to happen, like when there inspector pulls you in the Bay and says oh, you got a leaky seal that wasn't there when you last fueled
    Rideandrepair Thanks this.
  4. m16ty
    m16ty Road Train Member
    2,274
    4,963
    Jan 22, 2016
    Any time I need a semi-fluid grease, I go with John Deere corn head grease. I tend to think it’s the best semi-fluid grease on the market, JD uses it in their combine header gearboxes. Can be found at any JD dealer.
    cke, beastr123, kwswan and 2 others Thank this.
