Greasing 5th wheel with gear oil
Discussion in 'Ask An Owner Operator' started by mitmaks, Aug 13, 2021.
  1. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Advance enticed me with a discount code. They do that when you look at something, then leave the site. 25% off, free shipping orders over $30.
    6 bottles at $6.46 each, shipped to my front porch. That'll last me until next year.
  3. bad-luck
    bad-luck Road Train Member
    3,378
    6,253
    Nov 16, 2013
    Baltimore, Maryland
    I have a low lube Holland 5th wheel. You only need to lube the jaws. My old 5th wheel was a regular grease 5th wheel. I always used the red and tacky, always seemed to last the longest.
    feldsforever Thanks this.
  4. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Do your fifth wheels wear "even"? Mine obviously rubs in a circle all the way around, and about 3" wide. Couple other spots too. They will be bare of grease after a good run, but the rest of it is still nice and covered with grease.
    RStewart and shatteredsquare Thank this.
  5. kemosabi49
    10,913
    47,392
    Jan 13, 2013
    SW Arkansas
  6. shatteredsquare
    shatteredsquare Road Train Member
    1,404
    1,836
    May 23, 2014
    middle dirt
    gonna try that. does it last? seems like a few turns and it would be metal on metal again
  7. Elroythekid
    Elroythekid Road Train Member
    2,613
    5,670
    Sep 9, 2010
    Halifax Nova Scotia
    I have a friend that uses motorcycle chain lube. Sprays on a light coat, and with use it gets sticky and tacky. Says it doesnt take much and its cleaner? One can last months?
  8. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    This is what they had, I have a week to return it, if its wrong. It was just under 8.00. 162920380159613924698.jpg 16292038346631739290452.jpg
  9. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Can I use this to greese Every thing? I know the axles get the white container. But on the greese fittings on the truck.?
  10. AModelCat
    161,679
    Cold climates I've heard folks will cut the 5th wheel grease with diesel to thin it out. Apparently the grease gets so thick it inhibits the articulation and can actually put you in the ditch on icy roads.
  11. feldsforever
    1,453
    1,440
    Nov 22, 2019
