Green coolant maintenance questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dieselfuelonly, Mar 9, 2015.
  1. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    When I bought my T600 the radiator had just been replaced and it was filled with the green coolant. Nice and clean, don't see a need to replace it right now. I've always run the extended-life red coolant in everything I've had that's a diesel, so this is my first time dealing with keeping the green stuff in good condition. I know the coolant needs to be tested and you have to add SCAs periodically. NAPA didn't have the test strips in today, so hopefully they will show up tomorrow. As for the SCAs, I bought the Napakool (http://www.napaonline.com/Catalog/C...oling-System-Treatment/_/R-FIL4056_0478035182) bottles.
    Just wondering if anyone here still runs the green coolant and can offer some insight on keeping it in good shape. Any tips? Will the test strips give me an idea about how much of the SCA I need to add, or is it the kind of thing where I should just dump a bottle in, run it for a few days, then test again?
    Thanks
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    It's been a very long time since I used the green stuff, but yeah, add a little, then check again after a trip or 2 unitl you get it right.
    Another option is to convert it. Shell makes a conversion fluid that you just drain 1 gallon and put a gallon of the conversion fluid in. Not sure of the cost, but years ago I did when working for a fleet with 10,000+ trucks. The kit came with some test strips, to test if it could be converted, and a gallon of the conversion fluid.
    I guess cost would be the deciding factor here. With a big fleet the labor of draining, filling and disposing waste antifreeze may have been a bigger factor than the cost of new antifreeze.
    Heavyd and dieselfuelonly Thank this.
  4. rollin coal
    rollin coal Road Train Member
    13,134
    26,147
    Mar 29, 2008
    TN
    One other thing you want to check is to make sure they didn't forget to ground your new radiator to the frame or electrolysis will rot it from the inside out.
    dieselfuelonly and Ezrider_48501 Thank this.
  5. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    Huh! Never thought about that.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,539
    Jul 30, 2009
    Mapleton Depot,PA
    If the engine has a coolant filter, you can get filters that have the additive in the filter and release over time.
    dieselfuelonly Thanks this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,422
    6,446
    Aug 26, 2014
    Use distilled water, try to use the same name brand anti freeze, always use the same brand additive weather in a filter or bottle. If slime is continually building up on the cap it's probably in the rest of the system also, flush and fill. Filter # 4071 & 2071 have one unit of treatment in them (for maintenance). Filter # 4074 &2074 have 4 units of additive for precharge (amount for system change). I don't like to change colors on older water pumps. Strips work well but have a shelf life, old one's lye. A one unit filter or a pint of liquid every 15-20k usually keeps sca's in order. Conversion fluid, that's interesting,what color is it? I like to maintain my base colors, green, orange, red, or blue. If you don't you end up with reden or greenge which way be difficult to tell from rust or the driver that filled it up out of a mud hole and did not tell you. What is the advantage of converting it? There must be something to it or Shell would not be involved but I'am lost.
  8. dieselfuelonly
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Thanks for the replies everyone. If there's no worry of putting "too much" of the SCAs in then I'll just dump a bottle of he stuff in every 15k or so then and keep an eye on the coolant condition, and forget about the test strips. How often should I be replacing the green coolant completely? When it comes time I think I'll probably flush everything out and run the red stuff.
    There's no coolant filter on my 6NZ, maybe I should consider adding one in the future.
  9. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    I'm looking forward to flushing my green and running red. I use the test strips and so far they have come back fine. I haven't had to add SCA yet.
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    It was a very potent red, and the end result after mixing was purple. IMO, the advantage was that you did not have 10 gallons of waste antifreeze and you did not have as much labor involved. That adds up in a big fleet. Like I said, I don't know the cost of the stuff, so it may be insignificant for only 1 unit, but something to look into.
    The shop that I was in serviced over 600 trucks. What would it cost to dispose of 6000 + gallons of waste antifreeze? Plus, how long would it take for 600 plus drain and refills? Then you have the cost of 6000 gallons of antifreeze vs 600 gallons of conversion fluid. I may have very well been more expenisive for the fuild over new antifreeze, but adding in the other factors made it cheaper and easier in the long run, I guess. I'm not sure, I was just told that this is the cheapest way to convert to exended life.
    BoxCarKidd Thanks this.
  11. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    I wouldn't just dump a bottle in without using a test strip especially if it's clean. I also wouldn't dump a bottle every 15k without checking it. Having to much is as bad as not enough. Leave it alone until you test it then add a bottle if needed. I'm still running it in a 98 cat and can't see the benefits of changing it. I overhauled mine years ago and talked to cat about changing it over and they wouldn't recommend me doing it either. Tap water works fine without issues so no need to waste money on distilled. Just dip a test strip every so often and forget about it. It's that easy
