Grinding noise when idling?
Discussion in 'Freightliner Forum' started by matt660451, Jan 15, 2012.
  1. matt660451
    matt660451 Bobtail Member
    4
    NC
    I drive an 03' Columbia with a series 60 detroit engine. Whenever I am idling it makes a brief griding noise then continues to idle. The noise occurs at random time intervals. Sometimes it is subtle and brief and othertimes it is very loud and actually causes the rpm's to slow down and then catch back up to idle speed.
    Can anyone tell me what this could be? And is there an easy solution?
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Check the magnet on the oil pan plug
  4. runningman0661
    5,134
    14,734
    Mar 5, 2009
    Clover, South Carolina
    Sounds like the flux capcitar is going out.
  5. matt660451
    4
    NC
    This sounds like a goose chase...? I was not aware that the oil pan plug was magnetized. In the army we used to send people for riser grease for parachutes.
  6. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Or How about a good Snipe Hunt? Anyone?
  7. matt660451
    4
    NC
    Ok does anyone have any actual suggestions to my engine problem?
  8. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Sounds to me like you're hearing gear rattle from the transmission. At certain idle speeds it becomes very noticeable and annoying at times.
  9. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    Can you give us more details like when last overhaul done? How many miles? Last overhead was done?
  10. Bill104
    Bill104 <b>Pepsiholic</b>
    719
    769
    Dec 27, 2011
    Sacramento,Ca
    He wasn't joking about checking rheldrain plug if the engine is coming apart" you might find metal there, bit really it could be anything, if its laboring the engine you need to find it before it blows up while in rush hour in bum freeking no where, is your air compressor gear or,belt driven, look at your alt is it woobling at the shaft check the blades in the turbo if equiped, and last, make sure" the muffler bearing has grease in it.
    Mommas_money_maker Thanks this.
  11. matt660451
    4
    NC
    I was thinking about it some more today and your comment seems likely to be the case. The more I concentrate on where the sound comes from it sounds like it's coming from the transmision.
    In response to Mommas Money Maker, It has almost 900k miles and the last overhaul was done around 785k miles. I will talk to my boss about it, but I can already hear the complaining he will do. Somehow i'll be blaimed for it...
