Grocery team driving HOS tips/tricks
Discussion in 'LTL and Local Delivery Trucking Forum' started by Dean1986, Oct 5, 2017.
  1. Dean1986
    Dean1986 Bobtail Member
    11
    4
    Aug 13, 2015
    Hello delivery drivers!. Im new to local deliveries and this company. I'm on a new route with a new partner and we are running into problems with HOS. Running legal is important to us. The problem is dispatch is constantly breathing down our necks about ETAs and laying over at a hotel. Nobody else here at this division runs legal unless they have a trainee to work. I am beginning to understand why everyone works out of the sleeper. Because the stress of getting a random inspection by the safety department is infinitely less than dispatch calling and #####'n and treating you like a Crappy driver. They catch you working out of the sleeper or on break it's automatic final warning. You run legal and get behind they threaten you with sending you back to the extra board. I'm contemplating how my partner and I can work our hours to get them off our back. We've tried having someone come on duty earlier but for an 18 stopper with 20 minute drive times we both ran out with 4 stops to go. Ive tried suggesting changes to the routes so there is little to no back tracking but nobody listens. So are there any tips or tricks that a wise old delivery driver can give a couple of new drivers about HOS?
  3. scythe08
    scythe08 Road Train Member
    2,833
    3,636
    Mar 19, 2007
    Portland, Or
    That's the exact reason I dont do grocery anymore. You get threatened by safety if you run hard (illegal) but then are threatened by dispatch if you don't. When I ran for Albertsons, there was one dispatcher who was notorious for setting stops 2 hours apart regardless of transit times and would then scream at the drivers when the stores called looking for their freight. My last run there, I was sent on a 3 stopper all the way into northern Montana from North Salt Lake. Each store had a minimum of 120 miles between them, then 45 minutes to an hour unloading to pissed off store employees. Came back and he was screaming so hard that spit was flying out of his mouth. Having seen him do this before I knew he was just waiting for me to start screaming back so he could smirk and retaliate and then call the dock bosses and say " I just had driver wig out on me. I don't know why he did that".
    Screw grocery.
    LoneCowboy and Dean1986 Thank this.
  4. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    I would quit, that aggravation will escalate until someone "goes postal"
    Dean1986 Thanks this.
  5. Zigzag777
    Zigzag777 Medium Load Member
    460
    514
    Mar 25, 2013
    Down Yonder
    Time to move on down the road, you’ll never win in this situation.
    Better luck with a new employer!
    Mooseontheloose Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    If you are two drivers in a sleeper truck, you are a team. There should be like freaking 140 hours availible to both of you out of a total of 168 hours in a week to drive. That's enough to cross the USA twice. We have done it.
    Trip planning is key here. If you are told to be somewhere say... from Little Rock to ... Harrisburg PA that's about between 1100 miles to 1250 or so on the ground roughly, divided by 35 mph average you already know you will consume 31 hours driving time to get there. Loading, stops and unloading plus stops etc add time.
    Communication is key. If you know you are going to be late, call in and have a new appointment time made.
    Logs HOS is a legal document. If you lie in it, then sign it, you will be caught and then properly prosecuted and fined if not also placed OOS for it. Then you stand for being fired etc for cause.
    When your driving time is UP it's time to go off duty at home or into the sleeper berth. STAY there until your entire time is up and you have hours to drive again. DO NOT MOVE A INCH. Remember HOS is there to protect you.
    There are laws against anti corection. If dispatch is telling you to bust the HOS and run er or prohibiting you from using sleeper on your truck threatening you with firing etc... open a ledger pad and start keeping a documented in writing with date, time, names.. name names who said what to you. Build on that. You will need that information later if you DO get fired at unemployment.
    Stick to your log book, When it's time to stop and sleep or go off duty, DO IT. Let the truck burn down for all you care. Don't be weak against a predatory dispatcher and move on...
    One small word you need to use "No." its a very powerful word. If they fired you for saying NO then that's that you don't want to work for that ####ty outfit. Ive been there.
    Ive already got a big clue from your post saying sleeper is not allowed to be used. WTF?! Its there on that truck, it's assigned to you. USE The #### thing. Dispatch be ######.
    MACK E-6 and Dean1986 Thank this.
  7. Dean1986
    11
    4
    Aug 13, 2015
    Well the problem really is routing, one guy gets stuck two wheeling 4000 lbs down a ramp in a convenient store for one stop. That really screws up the next ETA which is a similar load. You just can't hunt for product and offload 60 cases of water or anti freeze and every thing else. In a timely fashion, which we are told is 40 minutes. All by yourself because your partner can't come on duty and help out. Guys that run illegal have a hard time getting home in their combined 22 hours of drive time. The odds are stacked against us. I really like the idea of keeping a ledger and names of who says what. Covering your own butt is now my top priority.
    Btw. We are alowed to use the sleeper as much as we need we just can't obviously be logged into the sleeper on peoplenet and go out and help the other guy.
    x1Heavy Thanks this.
  8. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    Get up and help the other guy. Logs be ######. Peoplenet too.
    But do not require it of your teammate. That way it's strictly a volunteer thing. I can get really bad and question getting up to go take care of nature or a midnight snack or whatever, that going to get regulated too? How bout a shot of profofol to ensure you out 10 hours in that sleeper?
    I don't know how many times Ive slept a little bit, sometimes getting up to keep wife company or perhaps helping out off the books for something small or even unloading. As long you got 4 hours in, a full cycle to REM and back you have rested somewhat. Most people do a full day on 6 hours sleep with no problem. The other 4 hours becomes free to do whatever off the books.
    4000 pounds is a bit much down a ramp. That's like two pallets. And probably was.... Most people in my area when they deliver to a store or something, they are not going nuts rushing about tossing stuff into the place. They get done when they get done and not a minute before.
    Dispatch is silly for imposing a 40 minute limit on a stop. Freight does not get moved in 40 minutes sometimes. Other times Ive had 30 plus kids climb into a trailer and off load 8 pallets of freight in about 6 minutes flat. What would have been hours unloading and counting as we go.
    There were many things that consumed small amounts of time here and there not logged. As far as the company and law is concerned my ### is in that sleeper. But in reality I might be doing small things and up to help spouse. And vice versa. Sleep will take care of itself.
    The biggest remaining problem is the dictatorial dispatcher saying you have to be gone in 40 minutes out of a stop. Tell him #########. Forget it. You will be finished with the stop when the customer SIGNS the BOL DELIVERED IN FULL and not a minute before. It might be a while.
    I tell you this, it's time you find another company. This will not end well with the constant conflicts over small things. They say a spark can burn a mighty forest, and you two are going to be the first thrown under the bus....
  9. MACK E-6
    48,826
    225,897
    Agreed. This is WAY more aggravation than it's worth.
    Zigzag777 and x1Heavy Thank this.
  10. aahensleigh
    aahensleigh Bobtail Member
    43
    5
    Jan 8, 2018
    Arizona
    My perspective would be succinct with the others here...too stressful, too negative, too many other opportunities out there!
    The truck doesn’t drive itself (yet), and until it does you are as much of a commodity as that freight.
    If you don’t value yourself, your time, and the sacrifices it takes to perform in this industry...no one will.
    Keep looking. The world is full of possibilities.
  11. Dean1986
    11
    4
    Aug 13, 2015
    I
    I appreciate your input and to everyone. My real problem is staying in the same area of work. I.e. delivery. I love being physically active and also driving the 53' trailer in tight spaces. I am just concerned nothing competes with McLane as far as pay. I feel like I'm at my wits end sometimes. Love the work don't trust the company
    speedyk Thanks this.
