Gross weight / axle weight
Discussion in 'Experienced Truckers' Advice' started by WMGUY, Apr 25, 2025.
  1. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    Hey guys I'm looking at grabbing a 53 x102 4 axle, tridem with a tag to pull with my 90 T600 3 axle. What measurements do I need to figure out what I can gross and be legal with bridge law. I'm based in Washington state and will being running the northwest.
    Thanks
  3. Knightcrawler
    Knightcrawler Road Train Member
    1,766
    6,912
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    Bridge laws vary by state. Google "truck bridge law".
    Gross depends on what your truck is licensed for. Usually 80,000. Sometimes 76,000, sometimes 105,000. It depends. Ive had trucks in each of them ranges when I was a company driver.
    If you are asking about the weight limits on the trailer only took me 3 secs to google that and find this:
    A three-axle tandem (tridem) typically has a maximum weight limit of 42,000 pounds when spaced 8 feet 1 inch apart, or 42,000 pounds for a 3-axle group with a minimum spacing of 3'6".
  4. Long FLD
    Long FLD Road Train Member
    12,540
    52,140
    Mar 4, 2015
    You’ll want to get your 5th wheel where you want it, then measure from the center of your front drive axle to the center of the rear trailer axle. Once you know the limit for that 6 axle inner bridge add your steer axle weight to that and that will be your max gross.
    Also make sure you check Oregon’s bridge chart as that will probably be lighter than every other state up there. Example: with the 8 axle setups I drove I was good for 104,500 everywhere except I could only go 101,500 in Oregon.
    Rugerfan, Bean Jr. and WMGUY Thank this.
