Ground issue, maybe?
Discussion in 'Peterbilt Forum' started by blessed2b, Sep 16, 2016.
  1. blessed2b
    blessed2b Bobtail Member
    6
    Jun 1, 2014
    07 Pete 340 cummins ISC 8.3L...ac works great until I turn on headlights or clearance lights, then just blows hot air...I can turn it on defrost & then compressor kicks in fine & blows cold out defrost vents but then I turn on ac switch & I lose instrument panel lights...unedumacated guess is a ground issue but I'm not sure where to check...I'm a decent parts changer but not a technician nor electrician & not real keen on reading a schematic even if I had one...any hints on where to check connections or any other help would be GREATLY appreciated, these hot Texas nights are killing me.
  3. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Doesn't sound like a part changer job. Also can't believe a ground problem. Can't think how one could backfeed into another. Someone been splicing into wireing?
  4. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Strange problems like that are very much a sign of a ground issue. Not saying that is what your problem is.
    I'd look around behind the dash. If you can't find anything I'd try grounding the panel lights with a jumper to a known good ground. See if that changes anything.
    blessed2b Thanks this.
  5. cdub304
    cdub304 Light Load Member
    162
    68
    Dec 7, 2009
    Rockford,IL
    take dash down and check wires...... sounds like you got a bare wire somewhere. trace wire lights n ac switch more than likely thats your problem
