GVW and additional tags
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by greaseburner, Sep 13, 2013.
  1. greaseburner
    greaseburner Light Load Member
    155
    45
    got a question.
    we do tonnage and hourly work. of course with tonnage, the more you can haul, the more you earn and fuel costs will are about the same.
    looking to buy another truck. current trucks are all tri axles 64,000 gvw. licensed for 66k.
    usually we do not get checked for bridge, they just look at your weight ticket and what your licensed for.
    i am wanting to haul more than 66k, so i am wanting a truck with a higher gvw. however, even the quint axle trucks i am finding are all maxed out at 64k to 66k. so are the extra axles just to help with your bridge weight and not your GVW?
    do they make a dump truck with a higher gvw?
    thanx
  3. Pilgrim007
    Pilgrim007 Light Load Member
    125
    80
    Sep 9, 2013
    As far as I am aware the tag axles are to spread the weight of the whole truck so there is less damage to the roads.
    Also GVWR = Gross Vehicle Weight Ratio means the maximum total weight of the vehicle and cargo plus driver and personal effects.
    GVW = Gross Vehicle Weight it may seem picky by it does make a difference.
    UVW = unloaded weight also called dry weight or tare weight, meaning the vehicle or trailer or both as it was rolling off the factory floor. ( without fluids hence Dry Weight).
    CCC = Cargo Carrying Capacity, Meaning the total cargo weight the vehicle and or trailer can carry including liquids driver and personal belongings and equipment. Put another way if you take a Dry Weight any thing you add to it becomes part of your CCC. Which also reduces your overall for hire cargo weight.
  4. Dieselgeek
    Dieselgeek Medium Load Member
    427
    209
    Nov 25, 2012
    Minnesota
  5. greaseburner
    155
    45
    yes on the supers. just they are darn expensive. but thanx for the post on them.
  6. snowwy
    snowwy Road Train Member
    20,539
    13,275
    Jul 6, 2009
    they may be more expensive. but you don't have to haul a trailer to pull the same weight.
    there is a company in phoenix. that expended their operations and came to salt lake with those trucks. they haul for the same rate as the locals. $60 an hour but can haul more then the locals. which would need their trailers and an added hourly charge for that trailer to haul as much.
    they came to salt lake to haul the concrete for the 2 new freeways salt lake is building. apparently concrete is cheaper then asphalt. even though it's thicker. but it sure don't seem to last long.
    not saying your situation would be the same scenario. but it's something to think about.
  7. greaseburner
    155
    45
    yeah, you are correct. i ran the numbers and it cash flows pretty good. just didn't want to have to go to the banker man. we run debt free.
  8. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    why would you want to pay more for your equipment, haul more per load for the same hourly rate.
    7.3 cowboy Thanks this.
  9. dilligas
    dilligas Light Load Member
    83
    42
    Sep 3, 2013
    Trucker math and logic I suspect.
