GVWR
Discussion in 'Questions From New Drivers' started by celery425, Mar 12, 2015.
  1. celery425
    celery425 Bobtail Member
    27
    Nov 12, 2013
    Does the GVWR go up the more axles I add?
  3. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Not necessarily, as the structure of the vehicle may be at its gross weight rating limit, with the existing axles already present.
    But in a "general sense", yes, the more axles on a vehicle, the greater the GVWR "should" be.
    Hard to answer that question with a definite yes or no, as more details need to be known, or in what context it's being applied.
    celery425 Thanks this.
  4. Allow Me.
    10,657
    12,161
    May 28, 2009
    Rancho Mirage, Ca.
    Let me take a stab at this……when a manufacturer manufactures a vehicle, it comes off the assembly line "rated" to haul a certain weight. That weight is "gross" allowed. If it has certain axles/tires that are under the rated capacity, yes adding an axle would increase the capacity. But, if they made that vehicle with max capacity axles/tires, then adding another won't do you any good. You couldn't add 5 axles to a vehicle with a frame structure not capable of carrying 100 K.
  5. truckon
    truckon Swamp Thing
    4,775
    15,916
    Dec 16, 2011
    Like I'd tell you!
    Usually whatever company does the work puts a upfitter tag on with the modification made, in that case it would also include a new GVWR for the vehicle.
  6. TripleSix
    128,289
    ^^^ It's one of those CYA things if you want to add extra axles to your rig. They will change that little tag in your driver's side door jam that was put there by the manufacturer, showing the new GVW rating.
  7. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    There's a little more to it than that - you have to factor in bridge law, as well. Bridge law typically benefits longer wheelbases, which is why you don't see old COE's pulling the 28' framed end dumps. Also, bridge law is going to be the law of the land - the Ford F750 has a manufacturer's GVWR of 38k.. cross a scale at that weight and see how you fare.
