gypomike
Discussion in 'Peterbilt Forum' started by gypomike, Oct 28, 2014.
  1. gypomike
    gypomike Bobtail Member
    I have a question maybe somebody can help me with...I have a '99 pete 379 that has non lockers (eaton 404's) except for inter lock, what do I have to do to make them into locking rear ends? Do you just change the back rearend? I would appreciate the help with this question. Thanks.
  3. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    you got it bud,,got to change out the differentials,,,might just want to do one,,will give you 3 wheel drive,,if you do one do the front,
  4. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    I just bought a 389 that only had inter axle. Bought a reman rear pumpkin with locker and they installed it. I think it cost me about 3500 cdn bucks
  5. gypomike
    thanks for the answer....I will check around some of wrecking yards
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Your truck probably has traction control through the ABS, so double check what axle the ABS sensors are on. You probably only have sensors on 1 drive axle. If you only install 1 rear with a locker, you'd get the best traction by locking the rear that does not have the ABS sensors. Then you have 1 locked axle and the traction control will be able help the axle that is not locked.
    If you find that you have sensors on both drive axles (possible, but not common), then locking the front diff is the better option.
  7. Luwi67
    Luwi67 Heavy Load Member
    747
    484
    Oct 24, 2012
    Long island
    I have a 97 379 and was looking into this very thing. What I found is that a locking center section will not fit in a non locking housing. There is a cut-out in the locking housing for the solenoid for the locking diff.
    flat top Thanks this.
