H2S meter and your Gas Mask
Discussion in 'Oilfield Trucking Forum' started by shurenough, Feb 24, 2016.
  1. shurenough
    shurenough Light Load Member
    66
    36
    Feb 24, 2016
    a 5 axle step deck or a 2 steering axle strait truck said on the cb radio , by the time the m2s meter goes off , you dont have enough time to put on the gas mask because your already dead. is that true?
    Edit, title edited by a moderator.
  3. QualityMike
    QualityMike Light Load Member
    288
    201
    Jun 19, 2011
    North Dakota
    Please restate your question.
  4. AModelCat
    160,259
    Did you mean H2S? Because yes that stuff will take you down.
    rabbiporkchop Thanks this.
  5. misc
    misc Light Load Member
    183
    133
    Mar 18, 2010
    Not true, I've had them go off before. It was always at a known h2s well, so I knew to keep an eye on the wind sock and get upwind. Never bothered with the mask.
    rabbiporkchop and BentleyB Thank this.
  6. AModelCat
    160,259
    They usually set the monitors to go off at around 5-10 ppm which isn't fatal but 300-500 ppm will likely knock you down. 1000 ppm or higher is pretty much instant death.
  7. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    If you're going to work in the patch educate yourself on Hydrogen Sulfide.
    It will kill you. On the flip side of the coin thousands of people work in h2s conditions daily.
  8. shurenough
    66
    36
    Feb 24, 2016
    I listen on the cb radio to learn something from the water trucks talking and Baker Houghs well service gossip. I seen chevron signs on a fence around a well . Chesapeake energy pickup trucks around canton Ohio don't talk on the cb radio.much
  9. austinmike
    107,233
    Only thing they told me was if it goes off run like hell and if you see someone on the ground don't try to help em because they are dead
    rabbiporkchop, Dharok, Lepton1 and 2 others Thank this.
  10. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    There are signs around every well/facility because every time there's gas/oil h2s is a possibility
    Get on youtube and search h2s training video
  11. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Those are sad stories for sure. Alot have died from simply trying to help a friend.
