Haldex 2 piece clutch brake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Aug 11, 2018.
  1. Dino soar
    Dino soar Road Train Member
    4,809
    26,922
    Dec 8, 2017
    I was wondering if anybody has any experience with the haldex 2 piece clutch brake.
    I really like the idea of it, because the clutch brake locks itself together when you push in the clutch. To remove it, there is a slot that you turn with a screwdriver (like a slotted screw) and it comes out. No long pins to bang in or cutting or any of that type of thing. It looks like a great idea to me. It looks like it's quick to change if you ever need to.
    I don't know how to put a link to it, but there is a PDF that explains how it works if you do a Google search.
    Oldironfan Thanks this.
  3. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    I USE them a lot because they dont seem to break as bad. A bad driver can break the pin style or the snap style fairly easy. I have only seen a few break the haldex out, they usually break the ears off. I think it seems to be the best replacement clutch brake. To really get them to lock, sometimes you need to push clutch down, then stick a bar over the roll pin and push the clutch again to get it set all the way
