Hanging Oversize signs
Discussion in 'Flatbed Trucking Forum' started by kubotaorange76, Jan 8, 2012.
  1. kubotaorange76
    kubotaorange76 Light Load Member
    269
    89
    Apr 9, 2010
    Monticello, Ga
    Picking up some oversize steel plate tommorrow (10'3"x20')
    Anyone have tips for securing oversize signs to rear of trailer without covering lights or tag? or is it ok to cover the tag? on truck and or trailer? ill post a pic of the back of my trailer shortly
    Ive got the front covered....should be a breeze with a few bungees
    How about flagging corners on something like plate steel? I was thinking either put chains on front and rear near corner and attach to that?
    Im all for any tips, advice etc...
    Btw im just hauling from winder ga to florence, sc
  3. haulhand
    haulhand Road Train Member
    I would just hang your sign under the lights on the back of your trailer and not worry about covering the tag. On the flags your idea sounds good to me or I use magnets for that kind of stuff.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,728
    Jan 30, 2010
    keep stroking.
    when in doubt flag all corners of load and all corners of outfit your driving. try not to cover plate on trailer and truck. it will cause less hassle going down the road or when you enter scales. also check and see if your required to have strobe lights. ga requires a $2 permit if your running strobes.
    kubotaorange76 Thanks this.
  5. cpape
    cpape Desk Jockey
    2,151
    2,263
    Jul 15, 2010
    Dubuque, IA
    We give our drivers short stakes to put in the rear stake pockets. This allows you to rig the sign over the deck of the trailer without blocking either the plate or the lights. If you have to cover either the lights or the plate, cover the plate. It is rare that anyone would hassle you over this.
    You don't have to flag the corners, just the widest point. Try to get it close to the front and rear of the load.
  6. XXX Trucking
    XXX Trucking Bobtail Member
    Bethlehem,GA.
    I haul a lot of oversize in GA and SC they souldn't mess with you about the tag being covered on the trailer, however GA will probably say something if the plate is covered on the truck.
  7. kubotaorange76
    269
    89
    Apr 9, 2010
    Monticello, Ga
    got some pictures of rear of trailer up now. i dont think theres a way i can avoid covering truck and trailer tag? thanks for the ideas and help!
  8. kubotaorange76
    269
    89
    Apr 9, 2010
    Monticello, Ga
    im picking up in winder at olympic steel, you haul out of there much?....looks close to home for ya
  9. cpape
    cpape Desk Jockey
    2,151
    2,263
    Jul 15, 2010
    Dubuque, IA
    You could probably cut 2 x 4s to fit in the rear stake pockets.
    Do you haul Kubotas?
  10. passingthru69
    Good suggestion there, cpape.
    Also take a 2x4 and put it in the center of the trl. and bungee the sign to it.
    That way it will keep from ripping up your o.d. banner..
    I had a sign board on the rear of the trl.,but I have to run mine all the time.
    On 2 metal tubes that slide in and out in case of a crane lift and I have to pull out from under the crane.
  11. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    Magnets work fantastic on steel and are only $5ish at Fleetpride. When I can't attach my sign to the cargo, I use the ends for my bridge in the rear stake pockets. I run a mesh sign as well.
