Hard knock at start
Discussion in 'Ask An Owner Operator' started by 77fib77, Nov 8, 2016.
  1. 77fib77
    77fib77 Road Train Member
    11,346
    73,835
    Jul 7, 2010
    St Louis
    I have an isx 870 in an 04 international. This morning 35 degrees after sitting for three days. I start it and it knocks hard for 30 seconds, then it settles down. 2 minutes in , it's purring. What is it?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    More than likely fuel knock. It cleared up after some heat was made, right? Start an old b- model cat or Nc Cummins. Listen to that knocking and banging until they make some heat!
    bzinger, whoopNride and 77fib77 Thank this.
  4. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,381
    Jul 16, 2012
    Bentonville Arkansas
    Same issue same engine. after my rods n mains new oil pump it's not as bad but still there so I'm assume it's normal
    77fib77 Thanks this.
  5. 77fib77
    11,346
    73,835
    Jul 7, 2010
    St Louis
    It doesn't do it when it's warm. It ran for 2 hours and shut it down for an hour and it ran reAl good at start up.
  6. whoopNride
    whoopNride Road Train Member
    1,649
    5,015
    Jan 13, 2008
    Miss.
    Just a cold Cummins. Like super hauler says, the old Cats and Cummins would shake, rattle and make you think they were coming out of the frame on a cold start. You would swear a rod was coming thru the block any second. And smoke the whole hillside up !!
  7. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Fuel leak somewhere? Feels like it's sucking air at start.
  8. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Could need the valves adjusted, while up there check out the rockers, inspect the cams... Could have a rocker loose or broke off in there
    Just an idea...
  9. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Could be starter issue if it knocks, batteries and cold don't do well on it making it work harder.
    Try plugging in engine block when really cold and then start, will tell you it's from the cold
  10. Ridgeline
    22,622
    120,360
    You guys over think this crap too much. It is a cold engine with what could be a bad grid heater. It is normal for a diesel to act like it is falling apart when it is cold and first started up. The knock is more or less the fuel not burning because the metal takes the heat away from the air being cold
    Below is what used to be with old cold diesels, brings back a lot of memories,
    whoopNride Thanks this.
