Hard start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ted Holcombe, Apr 12, 2017.
  1. Ted Holcombe
    Ted Holcombe Bobtail Member
    I have a 1993 Freightliner Condor with a detroit 12-7. I'm having trouble starting it after some 12 to 14 hours of being shut down. Have to prime it with gasoline in the intake manifold to start. Have changed the return check and come back to the same situation. Other than that, it runs smooth on idle and has lots of power. Fuel filters are clean. Any ideas ??
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Don't shut it off..?
    Try the garage. Maybe mods can move this for you...
    Ted Holcombe and G13Tomcat Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,821
    6,273
    Feb 4, 2009
    Usually the check valve at the back of the head fixes this 90% of the time.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,536
    6,604
    Aug 26, 2014
    Search block top right. Lots of info on that topic.
    Ted Holcombe Thanks this.
  6. Jace379
    Jace379 Light Load Member
    146
    97
    Mar 6, 2017
    It's one of two things on a Detroit, check valve at back of head or fuel pump that's behind the compressor. I've seen fuel drain back both ways. Also there's better ways to prime a Detroit then gas
    chalupa Thanks this.
  7. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    No kidding! good way to blow the head right off that thing. I remember using a gas rag over the air cleaner on wore out 2 cycles AND we built fires under the engines in Alaska but I don't recall ever sloshing them with raw gas.
  8. Ted Holcombe
    Jace, I know priming it with gasoline is dangerous, but how else can I fire it up if it doesn't have diesel in the line? It eats up the batteries (and they are new). As I said in my first post, the valve at the back of the head is new. How can I check to see if it's draining back through the fuel pump. I don't see any check valves there. And how else can I prime this engine?
  9. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    It only does it after being shut off for a while?
    One place I have seen issues with is the two fittings that go into the fuel pump. I have seen one of them have a hair line crack and cause loss of prime but show no leak. Is your return line directly in head or have a short run of line and then check valve? You could have an injector or more that is leaking down as well.
  10. Ted Holcombe
    Thanks for your input. Now, can anyone tell me how to prime the engine so it will start without having to use a little gasoline (I use about a 1/2 an ounce directlyu into the intake maniforl) ?? I certainly don't wsant to blow the head off
  11. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Crack the fuel line, plug the fuel tank vent, and pressurize the fuel tank with compressed air until fuel comes out the line.
