hard starting issue 2006 VED12
Discussion in 'Volvo Forum' started by Volvo 3031, Jan 23, 2013.
  1. Volvo 3031
    Volvo 3031 Bobtail Member
    9
    Jan 23, 2013
    siouxland
    I have gone through the earlier posts on hard starting. I have a 2006 vnl780 with the VED12 465. It has 809,000 miles. About a month ago it lost power and could barely make the slightest grades and started hard starting. I put fuel service through it and got most of the power back maybe 80%. My mileage is down partly because i'm reluctant to shut it off except where I could get help if needed but I believe my driving mileage is down also. I use to be at 6.1 now down to 5.2. I do get an occasional code for fuel pressure, a couple times while driving and a couple times while idling.
    I've had all 4 batteries replaced, and had a full service. Hot or Cold, it turns over so long that I'm afraid it will drain the batteries before starting. When it starts, it does so gradually.
    I've contacted several volvo dealerships and the service managers seem to agree it's bad injector. They say the injector cups were copper based and those are no longer available that the replacements are stainless. Therefore they say I can't just have the bad ones replaced but must do all 6 at a cost of around $6500. I think it is odd that none of them talk about check valves, or a weak fuel pump, or sensors, or wiring harness but rather jump right to injectors and cups.
    was there a recall on the injectors for that engine?
    This thing has been a nightmare, I have spent 25,000 in repairs in the 2 years I've owned it. Had to have both EGR's and the cooler replaced 2 weeks after purchase, then the lower front engine cover developed an oil leak...that repair went almost $8000. The A/C pump had to be replaced both summers. The oil pan had to be replaced as a crack formed from one of the mounting bolt holes. The crank sensor and harness were also replaced.
  3. nikmirbre
    nikmirbre Road Train Member
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    I had the same issues. They told me the same issue about the injectors/cups.(while I was on the phone describing problem) So I went to volvo charlotte, where I usually go to get work done, they said could be same issue. I was getting the fuel pump code also. It was leaking fuel and it would lose its prime after shut off. Replaced the pump for I think around 4OO$ and now all is well.....at least with that part of the truck
    Volvo 3031 Thanks this.
  4. nikmirbre
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    Sorry to hear of your troubles, If you hang around here long enough, some volvo owners have it much worse!
  5. Volvo 3031
    9
    Jan 23, 2013
    siouxland
    Thanks, i'll press them to look at the fuel supply Sorry I don't see how to register a "thanks"
  6. nikmirbre
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    Bottom left. Under your name and info.....
  7. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    I just bought 6 new injector cups the brass ones from volvo dealer in Omaha so they still make them $693.00 out the door. I installed them myself and wouldn't recommend trying it yourself unless you are a good mechanic/technician . Same D-12 you have so someones blowing smoke up you you know what!
