Has any one lowered a 379 with air trac suspension with out any issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pete3896nz, Jan 21, 2023.
  1. Pete3896nz
    Pete3896nz Bobtail Member
    11
    Jun 13, 2016
    Was looking into buying a Pete with air trac suspension and was wondering has any one ever lowered the front end
    we have a Pete with the low leaf suspension bags on the front end it runs super smooth
    my biggest question is since the air trac sits way higher then the low leaf will I get into drive line angle issues and how is the drive of the air trac compared to the low leaf
  3. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    Air trac is a lot heavier and stiffer suspension. Also the bags are shorter and only have half the travel of low air leaf. Not the best suspension for lowering IMO. But never done it either.
    Pete3896nz and Oxbow Thank this.
  4. Last Call
    Last Call Road Train Member
    7,568
    45,908
    Mar 15, 2021
    JMO .. but I myself wouldn't ever Consider switching from Pete low leaf to Air track.. its heavier and rides rougher
    Its JMO though
    Oxbow Thanks this.
  5. Pete3896nz
    11
    Jun 13, 2016
    Thanks for the info I was getting a truck for cheap I think my best bet would be a low air leaf cut out and swap it out
    Last Call and Goodysnap Thank this.
  6. Pete3896nz
    11
    Jun 13, 2016
    The truck has a air trac going to switch it over to low air leaf
    Last Call Thanks this.
  7. Last Call
    7,568
    45,908
    Mar 15, 2021
    I'am bad I missread your post .. .. sorry .. yeah that should be a big improvement ..
  8. Last Call
    7,568
    45,908
    Mar 15, 2021
    If your thinking about doing that .. if you can find a Flex-Air those are really good too .. IDK where your located but I know where there is a really nice Flex air well worth the money on good rails and 3:55 gears ..
