w w w.mnn.com/green-tech/transportation/stories/never-change-your-oil-again
I am new to trucking but this seems like it would save a lot of pain in the butt stops. If anyone has used this, please let me know. I would like to get some reviews. When I go to the website (electrolubegreen . com) It seems that they through out a lot of information but I don't know how reliable it is. I would really just like to hear from some people that have actually used it. I plan to be an owner operator one day, and if this saves me "time and money" as they say, I couldn't think of anything better.
I've asked around some other forums and haven't gotten any replies so far. If anyone could help I would love you forever. Thanks in advance.
Has anyone heard of this?
Discussion in 'Ask An Owner Operator' started by chillen808, Mar 7, 2011.
Oh!! BTW not spamming.. sorry if it seems that way, just really curious.
I might use something that would let me extend my oil change like a spinner because I can see the dirt it gets out of the oil, but I will never fall for one of those scams that say you never have to change your oil.
I wouldn't risk my motor on something as cheap as an oil change.. Sure it's okay to buy synthetic, I would even go as far to say those bypass oil filters are worth looking into. (with those you have extended oil change intervals.. )
In any case you MUST do oil analyis at regular intervals. I would also check with the engine mfg. for warrenty info.. These "never" change your oil add on's might void your warranty. How much $$ are you saving if you loose this? I'd feel more comfortable letting some company with a thousand trucks try this mystery oil stuff.. If you only have 1 truck.. you get put out of commission and then what?
I personaly don't use either.. I actually change my oil every 12-15k mi. & replace all filters... Grease... all the time... I have almost 750k on my 2001 Pete with no major engine problems. I expect to easily get 1 million out of it. Then the truck will be about 15 years old.... (I don't run a lot of mi per year.. maybe 60k tops) Just a FYI, I do high, wide and heavy freight.. -
I bought a '97 T600, 12.7L series 60, with 350,000 miles. I always used 2 gallons of Lucas with 9 gallons of Rotella. I experimented with oil change intervals and found that extending oil changes from 15k to 20k made little difference in oil analysis or consumption. Going to 25k showed a slight rise in metal wear, but a large rise in consumption. That is how I settled on the 20k interval. When the truck had 999,500 miles a wrist pin broke and I had a level 3 overhaul done at the Detroit shop in Champaign, IL. Up to that point, oil consumption was less than 1 gallon between changes. The mechanic working on my engine said he could still see hone marks in every cylinder.
Somewhere along the way I installed a Spinner oil centrifuge, and as I mentioned you could see the dirt and soot that it was getting out, but I didn't notice a major difference in the oil analysis.
