Has Anyone Retrofit Keyless Entry To T680/W990
Discussion in 'Trucks [ Eighteen Wheelers ]' started by The_Kenworth_w990, Dec 20, 2022.
  1. The_Kenworth_w990
    The_Kenworth_w990 Bobtail Member
    19
    10
    Dec 20, 2022
    I'm Looking For Information On Retrofitting A T680 Or W990 Built Without Keyless Entry.
    Background
    Found Out A Truck Was Built Without Keyless Entry Due To Supply Chain Shortages And I'm Looking
    For Options To Remedy This Issue. Figured It May Be A Common Issue Or Topic To Those Finding
    Similar Trucks Built In The Same Timeframe.
    Parts
    I Think I've Found The Module And Need To Locate Some Remotes (Unless Someone Here Has A Module And Remotes Before I Lock The Others Down) NOT Looking At Aftermarket, Looking For Factory "Plug And Play"
    Research
    Looking For Some Advice If Anyone Has Already Done This. I Tried Searching Google, Facebook And This Forum Before Creating This Post, But To No Avail.
    Questions:
    (1) Where Are The Connector Plugs On The Wiring Harness For This Kit?
    (2) What Settings In The ECM May Need Changed If Any At All.
    (3) Anything Else I May Want To Consider Or Advice You Have On This Topic?
    Summary
    If Someone Has Been Down This Route And Has Any Advice, Or Selling The Parts I Need To Do This Retrofit I Would Be Glad To Know IF Its Possible And What It Would Entail To Do So. Thank You For Your Help And Advice!!!
  3. MacLean
    MacLean Road Train Member
    1,307
    3,887
    Sep 12, 2017
    What about an aftermarket remote start unit that does that? I don’t think I’d hook up the remote start capabilities but the rest could be good and maybe cheaper.
  4. The_Kenworth_w990
    19
    10
    Dec 20, 2022
    I Considered That But Most Are Hardwire Units And Need Splicing Which I Am Fully Capable of Doing But Prefer To Utilize A Factory Plug And Harness If Adding A Factory Module Can Prevent Invasive Wiring. Small Details But That Is Why I Am Leaning To The Factory Unit Instead Of Aftermarket.
  5. Renosteve
    Renosteve Bobtail Member
    7
    4
    Dec 21, 2022
    Exactly this. Just buy Factory and have the peace of mind. Even a hood latch. Buy factory. My doorman one made it 2 months...
    The_Kenworth_w990 Thanks this.
  6. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    Talk to your dealer. Rh door module needs replaced and then remotes programmed. Very easy to swap
