Have 1999 Freightliner century no Jake's no cruise brake engaged alarm goes off for a minute 45
Discussion in 'Freightliner Forum' started by James Edwards, Sep 15, 2019.
  1. James Edwards
    James Edwards Bobtail Member
    After turning on the key changed all switch's in air manifold had switch's color coded so no didn't get anything backward have high idle with brake popped subbed in new clutch switch no change am getting no signal on circuit 125 drl parking brake c/o just that circuit need a wiring diagram and where that wire goes.
  3. 201
    201 Road Train Member
    12,065
    24,636
    Apr 16, 2014
    high plains colorado
    Sorry, you lost me after "After". That's an old modern truck, electrical gremlins will drive you nuts. I say this everytime with older trucks, start with a good ground to the cab. Bad grounds do all kinds of funky things. I drove a '99 Century for a friend, it was a nice truck, but had almost 900 grand, and was beginning to do the same stuff. Good luck.
    x1Heavy Thanks this.
  4. Rideandrepair
    17,231
    55,917
    Aug 8, 2015
    How about brake pedal switch?
  5. Hammer166
    7,354
    26,458
    Aug 18, 2007
    ~8600+' and loving it!
    Parking brake switch is normally on the back of the brake valves. Check switch with ohm meter, check voltage as well.
