The trainer says I'm doing really well. Of course we are pretty much teaming it. I drove from Corning CA to Napavine WA on I-5 last night while he spent most of his time in the sleeper snoozing. He did come out when I went up and over the Siskues? (I have no idea how to spell that). I drove into Loves with 15 minutes left on my 11 hours and this is only the start of week 2. I'm only supposed to be driving 4 hours a day and no more. Oh well I kind of enjoy it but I wish I could do more day driving. I'm more awake then. Enough whining.
I'm having a big problem controlling the truck. I do good driving, turning, etc loaded and unloaded my problem is when I go to unhook a loaded trailer.
I get it all set start the truck hold the brake and slowly let out the clutch while in 1st gear. As soon as the clutch engages the truck lurches forward and scares the heebie jeebies out of me. How can I get it under control while dropping a loaded trailer? I didn't have this problem with the empty trailers at school although the school trucks are massively different than these new Kenworths.
Any suggestions would be greatly appreciated.
Have a big control problem
Discussion in 'Questions From New Drivers' started by TruckerGonnaBe, Aug 27, 2014.
Page 1 of 7
You need to --IF LOADED HEAVY--
#1, crank down the pads to the ground in high gear, then put in low gear then crank more until you hear air start to bleed off the air bags (add additional 5-10 cranks in low gear if no air dump valve)
#2, then (if you have air suspension dump on tractor), dump the air, wait 4 seconds then slowly pull out, then reapply air to bags.Tonythetruckerdude, OPUS 7, Tracks and 7 others Thank this. -
You need to break the friction between the fifth wheel and the trailer. That sometimes can make the tractor lurch a bit when you pull out from under it. Sometimes the trailer will drop and bang if you've left air between the landing gear feet and the ground and you pull out with too much snap. (I did that once and my trainer barked at me, "Poor gear selection." I always eased it out from under in first gear after that.
Sometimes I crank the feet of the landing gear until they touch the ground, then give it a half or one more turn after that so they take some of the weight. Tractor slides right out. And I pull out in first gear. doh.
I wouldn't think that you need the foot valve engaged when you start the tractor before you unhook. The trailer isn't going anywhere because it's got no air supply. The tractor is in neutral and you've got the clutch pushed in, then you put the shifter in reverse and feather it out and gently pull forward. Try using the front part of your foot on the clutch to have more fine control over it.
Then, when you pull out, feather the clutch out until the tractor moves. Don't be afraid of stalling it, as the computer won't (shouldn't?) let that happen (Do the K-Dubs have that feature, anybody?). It's a feel you will develop for how the tractor operates.
Is your trainer making you shut off the truck when you get out to crank the gear and pull your pigtails and pin? I guess that's one way to do it.
I've always left the tractor running after I parked the combination, set the trailer brakes and pushed back on the pin a little with the tractor (if I thought it needed it in certain yards or whatever), then popped the tractor brake. Then I jump out and crank gear, pull pin, pull pigtails, always in that order every time.
If you think you're driving too much, tell your trainer that. He might be waiting for you to push back, waiting to see where your boundaries are. Some are like that. Give him a wakeup call.
Just my two cents, FWIW.
Edit: What STexan said, too. air and airbags. When you crank the trailer up a bit, you'll hear the airbags filling to make up for it, since the weight is coming off the fifth wheel. The height valve will start to compensate for that lower weight on the fifth and you'll hear it hissing air. When I hear that hiss I know I'm good to go to pull out. Dumping the bags works in a jam, too, like if the drop site is uneven, gravel, or sloped and you're spinning to get out from under the trailer. Engage axle locks, drop air, wait just a bit then pull out, unlock differentials, refill bags, party on.Last edited: Aug 27, 2014
the airbags aren't filling. they are bleeding off.
as you raise the trailer the truck suspension raises, therefore, needs to bleed off air to level off.
as for you statement of putting shifter into reverse. all that'll do is relock the 5th wheel pin. but we all know you meant to say forward, cuz that's the only way your getting out from under the trailer.
as for the jerking. not everytime it works out perfect. but you'll get used to it.
as long as you dont drop the trailer on the ground. that's what matters. -
Same old same old. Trainer turns student into team driver, he makes big bucks for you driving miles for which he get paid while he sleeps. Heard it more times than I can remember.Skydivedavec, SHO-TYME, hal380 and 2 others Thank this. -
hal380, Chinatown, Skydivedavec and 1 other person Thank this.
How much experience does your "team mate" have? -
hal380 Thanks this.
Page 1 of 7
