Have a Volvo 780 455 horsepower 12-spd auto can I do heavy haul
Discussion in 'Volvo Forum' started by Weedieman, Aug 3, 2022.
  1. Weedieman
    Weedieman Bobtail Member
    7
    7
    Aug 3, 2022
    I just purchased a RGN 40 ton trailer and I want to know if I can do any heavy hauling with my Volvo 780 455 horsepower 12 speed auto transmission
  3. beastr123
    beastr123 Road Train Member
    2,811
    22,908
    Jan 2, 2014
    Moose Jaw SK CAN
    455 is a bit low if you are going to play heavy in the mountains but is do-able. The I-shift is a good transmission as long as you don't mash it in the lowest 2 gears.
    In Canada that tractor is fully capable of pulling super-b's(8 axles) at 140k but most owners turn them up to 505hp.
  4. 86scotty
    86scotty Road Train Member
    4,415
    11,751
    Aug 27, 2017
    Appalachia
    Yep, go have a dealer turn it up for you. What year? It cost me about a grand to have my 2015 D13 turned up from 425/1500 to 500/1750.
    Gamechanger.
  5. Weedieman
    7
    7
    Aug 3, 2022
  6. Weedieman
    7
    7
    Aug 3, 2022
    I'm not trying to pull crazy I was just trying to get my feet wet and try to stay with loads 55-60k that will keep my overall weight under 100,000
    My truck weight is 20300lbs my trailer weight is 15300lbs I run out west here in America I avoid the big mountains on 70 in Colorado I try to avoid all of the big mountains I run a lot of flat land from Chicago all the way to Boise Idaho on 80 so you say your trucks in Canada like the one I have run heavy with no problem
  7. Weedieman
    7
    7
    Aug 3, 2022
    Not looking to go that heavy just trying to stay right around that $100,000 and under just want to get where I'm making a little bit more money where I can step up and get me a more powerful truck thank you for answering my question
  8. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,263
    Nov 14, 2021
    ALBERTA
    Change the power to 500 HP minimum.
  9. Weedieman
    7
    7
    Aug 3, 2022
    Ok so 500 with that 12-speed eye shift transmission will be okay for how much weight can I pull with no problem if you can tell me
  10. Another Canadian driver
    1,181
    4,263
    Nov 14, 2021
    ALBERTA
    110k pounds/50T.
    I do it with a 2012 VNL 64T780 500HP 2.64 rear ends, direct drive I-Shift.
    68mph/1500 RPM.
    110kpound fuel mileage is 6.5 miles/US gallon/year average, no mountains.
    I could do 7 miles/US gallon average if I limit max speed to 60/mph 1300 RPM top.
    I hope it helps you.
    beastr123 Thanks this.
  11. Weedieman
    7
    7
    Aug 3, 2022
